Newbie: Is the Pioneer LX86 too "bright" for MA Radius HD range?
11 replies [Last post]
victorleong
victorleong's picture
I'm a newbie here and with home cinema setup.
I am torn between the Pioneer LX86 and the Yamaha A3020 for my (soon to be purchased) MA Radius HD speakers.
I have read through the forum for earlier comments - but i thought i might get some fresh feedbacks with those who have bought/tried out both these amps since it was released in Q3 last year. I am based in Stockholm, Sweden - and have been unsuccessful in locating a demo for the A3020. However, I finally found a shop with the Pioneer amp to match the Radius 90 & 45 HDs.
My decision on the MA Radius range is based on my available budget and the space in my living room. I am also trying to purchase a set of good speakers which can be flexible enough to be re-installed in my study room in the future when i upgrade (perhaps to the MA silver range). Therefore, my amp selection should also be flexible/powerful enough to pair with future speaker upgrades. Reading through the earlier forums from 2012, i notice there were quite many comments about the Pioneer amp being bright compared to the Yamaha, especially for the MA Radius range (which sounds bright already). I typically will use the speakers/amp for movies on my Samsung LED tv and listen to music (mostly jazz, classical, and pop).
My MA speaker 5.1 setup looks like this (ALL Radius range):
R270HD floorstanding - front left/right
R225HD - front centre
R90/45HD - rear left/right
370HD - subwoofer
As for the rear speakers, i am still thinking between the MA R90/R45.  This is because my sofa is back to the wall, and I probably can move my sofa further front and have up to 0.5-0.8m to place the rear speakers (between my sofa and the back wall). Is it true that the rear speakers are better placed just in front of the back wall compared to the corner?
Would be grateful for any advice or sharing of experience i can get?
Cheers,
bigboss
bigboss's picture
RE: Newbie: Is the Pioneer LX86 too "bright"
Sound is a personal preference. I personally didn't like the Pioneer amp (LX82) with Radius HD as it was too bright for my taste. Yamaha is one of the easier amps to partner with. With regards to speaker placement, check this guide: http://www.dolby.com/us/en/consumer/setup/connection-guide/home-theater-...
__________________
David@FrankHarvey
David@FrankHarvey's picture
RE:
If you can move your sofa away from the back wall, it'll certainly improve the sound you will hear, and your onboard EQ will have less work to do.
The Pioneers aren't bright receivers. It's one of those myths that are spread by people who either haven't heard them, misinterpret "bright", or like a smooth, warm sound. It is true that in comparison to the Yamaha receivers they sound more "vivid" and "energetic", I'd best describe them as, so they sound as though they have a more "forward" sound. If you feel they do sound bright, there is the X Curve facility, which allows you to reduce HF output by up to 3dB (half) in 0.5dB steps. This is very handy for taming bright sounding speakers or rooms that are reflective very easily.
The Yamaha's do seem to have a little more warmth and fullness, which is something many like, and may find that preferable with some speaker packages. You will find that although the Pioneer and Yamaha receivers sound different, they both go very well with the Radius range.
I would recommend looking at the SVS SB1000 subwoofer, which will outperform the R370HD for both music and movies, and will allow the Radius speakers to perform better too (many reasons for this). It is £25 cheaper in this country, but I'm not sure about the price difference there.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
victorleong
RE: Newbie: Is the Pioneer LX86 too "bright" for MA Radius?
Thanks heaps, guys !
I think i'm pretty much decided on the Yamaha A3020  Cool
BigBoss - i've checked the link you forwarded me before. Only problem is my living room does not have the provision to place the rear speakers on both corners due to the corner wall on one side (right)  Crying The only option i have is to move my sofa front a bit - it's currently 10ft away from the TV, i might be able to squeeze forward by 1.0-1.5 ft max to allow space for the rear speakers behind the sofa on both ends. The MA stands for the R90HDs is measured at 38.5" and is just a few inches higher than my sofa. I just hope it won't be too near my ears !
Frank - The latest March issue of WHF states that the Pioneer LX86 does sound a little "bright". My choice of the Yamaha leans towards the fact (from my readings) that it is indeed easier to pair with a wider range of speakers or perhaps requires less configuration/calibration to achieve the optimal sound through the pairings. Whichever way, for a newbie like me, i just want to make sure that my investment does not require too much complicated calibration. My leaning towards the Pioneer was driven by the rather significant price difference. The Yamaha A3020 retails at GBP2000and the Pioneer LX86 retails at GBP1700. And this is only for the amp i.e. excluding the speakers (for 5.1) and cables! I might be able to negotiate down by 5-8% on the retail price, but unfortunately, i am unable to get the whole package (i.e. MA speakers and Yamaha amp) from the one same dealer. One does not carry Yamaha, and the other does not carry MA. Sigh.
Anyways, i will be going for a demo of the R90 tomorrow with the LX86. Have not been able to locate a retailer with a Yamaha A3010/3020 amp to test with the MA speakers. So i can only rely on what i read online.
Speaking of which, is there a big difference between the Yamaha 3010 and the 3020? Reading from the specs in WHF, the only difference i spot is the number of HDMI input channels.
victorleong
Sorry "Frank".... i meant David  Tongue
bigboss
bigboss's picture
3020 has built-in AirPlay.
__________________
victorleong
RE:
I thought both the LX86 and the 3020 have built-in Airplay?
bigboss
bigboss's picture
RE:
I was talking about the differences between 3010 & 3020.
__________________
ric71
ric71's picture
As an ex RadiusHD owner I would say get the R90HD's over the R45. Huge difference in performance and can be used later in another room as a stereo pair. As David said go elsewhere for the sub. The 370HD really isn't that good at all for the money. Much better can be had elsewhere at a similar price. I sold mine within weeks of buying.
__________________
Anthem MRX 300(used as processor),Anthem Statement A5 power amp,MK S150MKII's LCR,MK S150T rears,Paradigm Studio Sub15,Perfect Bass Kit,Sonos ZP90 ,Qnap NAS,Pioneer BDP-LX55,Isol-8 Cleanline2 mains conditioner,SKY+HD,Audioquest Diamondback interconnects. ATV3,iPad4.
duaplex
duaplex's picture
Never buy such expensive equipment without a demo and certainly do not buy based on the experience of others. The Pioneer and Yamaha are exceptional receivers, but after listening to both, the Pioneer wins for movies, hands down for me.  But that is my personal preference as I like a more punchy and energetic sound as opposed to warm and laid back.  Now, having said that, I preferred the Yamaha for music.
__________________
Panasonic 65" 3D TV (P65VT50), Pioneer LX83, CA, Azur 751BD, PS3, Water Cooled Xbox 360 (Modded), Nintendo Wii U, Sky HD+, i7 PC overclocked with 6850 HD Radeon, CM8 Fronts (Bi-Amped), CMC Center (Bi-Wired), DS3 Dipoles, PV1 Sub. Van Den Hul M.C. Snowtrack >Halogen Free< wiring, Chord Active Silver HDMI's, Cabridge Audio AUD700 Analogues Interconnects, QED Signature Subwoofer cables, Chunky Monkey custom oak AV cabinet.
victorleong
RE: Newbie
Just came back from a demo on the MA Radius speakers - both with and without the Pioneers LX86 amp. He's also willing to shave off 12% off the retail price. I am negotiating for them to come setup in my house for free too Tongue but i doubt that's gonna happen.
Sounds great... trying to locate a retailer that i can demo the Yamaha A3020 with the MA speakers - no luck to date. But will keep searching.
The retailer recommended the Carnival Classic chord/cable to connect the Yamaha/Pioneer amp with the Radius front speakers (270HD and 225HD). Anyone heard of this cable? Is it of good quality and/or suitable for my setup?
victorleong
RE: Newbie
The retailer also suggested the Velodyne MicroVee or Velodyne SPL-1000 Ultra subwoofer to go with the Yamaha amp & MA Radius speakers.
Any advice would be appreciated.
