Need help with equipment upgrade
6 replies [Last post]
Stigmunson
Stigmunson's picture
Hello people,
Here is my configuration
Fronts - Jamo S606
Center - Wharfedale Diamond 10.CS
Sub     - jamo SUB 210
A/V reciver - Yamaha RX-V567
My living room is 4x10 metres,and i am not satisfied with my fronts,
As u can see i need some recommendation for fronts,center(?) , and sub,
My idea was
KEF Q900 fronts
KEF q600 center speaker
and
KEF Q400 for sub lets say,
Other chaeper soluton was
    WHARFEDALE Diamond 10.7 fronts
   Central speaker same
Wharfedale Diamond 10.GX for sub
I am just a litlle woried about reciver,has he enough power for taht combinations?
I am opened for all sugestions,
Thanks a lot
Stigmunson
RE: Need help with equipment upgrade
anyone?
Triggy
Triggy's picture
Stigmunson wrote:
Hello people,
Fronts - Jamo S606
Sub     - jamo SUB 210
My idea was
KEF Q900 fronts
and
Thanks a lot
Just to let you know your post is in the wrong area.
This is Hifi, needs to be in Home Cinema.
Cheers.
__________________
Cyrus 8XP (with Ianmac filter) & PSX-R/Cyrus X Power/Cyrus CD 8SE2 & PSX-R/Denon TU1800 DAB/Sony MDsJE530/MA RS6 speakers/Tellurium Q Black, Chord Chorus2, Chord Cadenza, Chord Cobra3 interconnects/Tellurium Q Black speaker cable/Tellurium Q Black Links/Clearer Audio Copper-Line Alpha mains cable/Black Ravioli pads/Entreq Minimus
Stigmunson
now theme is on right place,
anyone have any suggestions about upgrade?
thnx
jjbomber
jjbomber's picture
If you are going the KEF route, I would try and find some Dipole rear speakers. The old KEFs were one of the few that had full THX Select and Ultra. They were designed specifically for the job, rather than adapted from front speakers. I'm a KEF fan, but others to consider would be the Dali Zensor 5 series, the Monitor Audio Apex or, top of the tree, Bowers & Wilkins CM9. Not sure what country you are in, so not sure of availability and back up.
bernienagig
bernienagig's picture
I have just got a new Genie 1.3 to replace my old trusted Revolver. However I have also just been given a Systemdex IIX from a frens attic. Have played it-without grounding wire-missing -& sounds great! the arm is loose & have done some research & discovered it is a Origin live OL-1 arm.
What would give me best results here? Restore Systemdex? Upgrade the Genie with the Origin Live arm? + how difficult would this be to do-am very handy!
Would be very grateful for any suggestions & tips!-forgot-am running from an old yamaha Amp, Denon tape, denon tuner, Denon Cd player+ a Pioneer CR-r  + Warfdale speakers.
Many thanks
Stigmunson
i think q900 would do just fine i think,as u said i watched cm9 from b&w but they are much more expensive,best way is to hear both speakers if possible,hm...
Anyone have expirience with keff q900 and b&w cm9?
thnx
