Need help setting up Tacima CS929 6 Way Mains Conditioner and Radio Frequency Interference Filter
4 replies [Last post]
Hello I am a long time lurker but first time poster.
I am need of advice, I have just brought a
Tacima 6 Way Mains Conditioner and Radio Frequency Interference Filter CS929C/BP and a Merlin Tarantula Figure '8' mains cable to go with my AV setup
My Av setup:
Onkyo TX-SR608
Samsung UE46C8000 3D LED HDTV
Q Acoustics 1010i 5.1 Speakers
Sky+ HD
Playstation 3
Xbox 360
And they are all connected to my amp using the best HDMI cables and interconnects and all the above equipment is connected to a Masterplug Master series 8 way surge block.
I am wanting to now connect the above to the new Tacima CS929 but have been been told that I should not connect the Amp and Subwoofer to the Tacima as it strangles the amps power.
So my plan is to Connect the HDTV, Sky Hd, Playstation 3 and Xbox 360 to the Tacima and then the Amp and Subwoofer to the Masterplug Master Series surge block.
What do you think? Is this the best way and also in what corresponding order do I plug the equipment into the Tacima?
Then I am going to use the Merlin Tarantula Figure '8' mains cable on my Sky+ HD box.
I wanted to replace my onkyo and TV mains cable but they cannot be unplugged as they are not removable leads. Sad
Thanks in advanced.
hammill's picture
What I think is that it is a
What I think is that it is a good job you cannot replace the onkyo and tv mains cables, as it would be a complete waste of money. Fancy mains and HDMI cables are a con and I am sorry they fooled you.
Oldboy's picture
RE: Need help setting up Tacima CS929
Where did you get the impression that you shouldn't plug your amp and sub into the Tacima? I've got both plugged into mine and have had no issue at all, the gains have been slight but it's definately an improvement from when I had them plugged into the mains sockets. All you are doing with the Tacima is "cleaning" the mains power which has no detriment to the performance of electronics in fact it's quite the opposite and the point in buying one in the first place.
Don't worry too much about replacing the mains cables of your gear as the Tacima should give you some gains in performance alone, it's debateable as to wether or not replacing mains cables makes any difference at all. It did make a difference when I replaced the mains cable on my sub but I don't intend on replacing any others as my equipment is plugged into the Tacima.
__________________
Living Room:
Samsung UE55F8000 (THX Pro calibrated), Yamaha RX-A2020, Dali Zensor 5 7.1 (front presence config), Panasonic DMP-BDT500MR, WD TV Live, Marantz CD6003, Marantz PM6004, Beresford TC-7220 MKII, PS3, QED Silver Anniversary XT speaker cable, Wireworld Chroma 7 HDMIs, Chord Crimson Sub and RCA, Chord Superscreen Mains Cable, Netgear Prosafe 8 port Gigabit switch.
Bedroom:
Samsung UE40F7000, Sony BDV-E3100 5.1 Home Theatre System, X-Box 360.
Mobile Devices:
Google Nexus 5 Phone, Google Nexus 7 Tablet, Sony PS Vita.
duaplex's picture
All devices have power conditioners built into them. I am not entirely convinced by them, there can be gains in the right system but not for all.
check this out
http://www.youtube.com/watch?v=LyI85XOKzZ4
__________________
Panasonic 65" 3D TV (P65VT50), Pioneer LX83, CA, Azur 751BD, PS3, Water Cooled Xbox 360 (Modded), Nintendo Wii U, Xbox One, Sony PS4, Sky HD+, i7 PC overclocked with Nvidia 780 GTX, CM8 Fronts (Bi-Amped), CMC Center (Bi-Wired), DS3 Dipoles, PV1 Sub. Van Den Hul M.C. Snowtrack >Halogen Free< wiring, Chord Active Silver HDMI's, Cabridge Audio AUD700 Analogues Interconnects, QED Signature Subwoofer cables, Chunky Monkey custom oak AV cabinet.
AnotherJoe's picture
No problem plugging everything into the conditioner. Its only there to give surge protection, and smooth out any spikes in your electricity supply
__________________
Server Synology 12Bay DS2413+, Synology 8Bay DS1812+, Sky+HD
Lounge Samsung UE55D9000, Denon DBT-3313, Onkyo TX-NR5009, Tannoy Arena Highline 500 LCR, ACRyan playon!HD mini2
Reception Samsung UE46C8000, Panasonic BDP310, Sony STR-DA5400ES, KEF2005.3, ACRyan playon!HD mini2
