My new set up.
16 replies [Last post]
Steel_Lynx
Steel_Lynx's picture
Hi all!
Ok, so after loads of looking around and basically using WhatHiFi as my buying guide I finally managed to get all my bits together and set it all up (yay me).
I have a Samsung UE55ES8000 Television, connected to a Yamaha RX-V673 amp, and wired in to the router with a CAT 6 ethernet. The Bowers and Wilkins MT-50 package, sitting on Partington Super Dreadnought stands (unfilled at the moment), using QED Silver Micro cable.
The tele is plugged in to the amp via a Audioquest Cinnamon HDMI and the SkyHD is plugged in to the amp using a Audioquest Cinnamon HDMI and a QED Profile optical cable ( I was told I needed that for the sourround sound to work), the Sub is connected to the left 'Line in' using a QED optical as well. My Xbox360 is also plugged in but using the standard HDMI cable that came with it (for now)
1: I was wondering if I need an optical cable for the television as well? And also is the sub connected properly as I thought I followed the instructions but it failed the set up test (using the supplied YPAO thingy) Error W-3 or something like that and wondered if I've maybe set it up wrong (first timer and all that)
2: Also, I realised (after a lot of effing and jeffing feeding the cable through the wall and getting the tele back up) that these decent HDMI cables are directional. The arrows point 'from' the tele and 'In' to the amp, is this the right way round (it says it's supposed to go from the source but wasn't sure if the amp is now considered the source) I'm hoping I've been jammy and got it the right way round but would like to be certain!
3: Do I need the tele to be connected to the net or would it be best for me to use the amp?
Sorry for the long post, but it took me a while to save up for all this equipment so would like to be sure I'm getting the very most out of it!
Thanks in advance for any help you can shed on all this as it's still all very new (and it has to be said quite confusing/daunting).
__________________
Samsung UE55ES8000 3D T.V / Yamaha RX-V673 Amp / B&W M1 Front, Centre, Rear / B&W ASW608 Sub / SKY+HD / Xbox 360.
BenLaw
BenLaw's picture
RE: My new set up.
(1) HDMI only is fine for TV to amp. The sub does not connect with optical. There should be a sub out on your amp which connects to the sub via a single RCA cable.
(2) HDMI is not directional, don't worry. As long as it's working, it's fine.
(3) You don't *need* it, it depends what 'smart' features you want and which component can provide them.
I'd also comment that your choice of stands seems a bit extreme for those speakers.
__________________
HiFi   /   A/V   /   Bedroom
RobinKidderminster
RobinKidderminster's picture
Online
RE: My new set up.
Adding just a little to Bens advice. The Yamaha needs to know that the audio is from optical and not hdmi for the sky box. DD programmes should show Dolby Digital and not DDPLIIx. The sub connection seems odd. How have u used an optical???
Use the subout from the Yamaha.
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
Steel_Lynx
RE: My new set up.
Sorry, it's an QED Precision Audio cable, not an optical cable at all..... It is plugged in to the left 'line in' on the sub and in to the 'Sub 1' socket on the back of the amp.
Very pleased the direction of the HDMI cable isn't important (it said it was directional on the back of the box so assumed it was fairly important)
I went for the Super Dreadnoughts as they got a good write up, I didn't realise it was possible to get stands that were too good for the speakers. Thought it was the other way round. At least when I upgrade I'll be able to just change the speakers and keep the stands.
__________________
BenLaw
BenLaw's picture
RE: My new set up.
That sounds like a subwoofer cable and it sounds like the right connection (having viewed a pic of the back of the sub). Is the sub definitely switched on? Is there a menu setting to switch the sub out on?
Great speaker stands, it's just they'd normally be used for a chunky, full sized speaker. As you say, handy for any future changes  Smile
Keep us updated.
__________________
Steel_Lynx
RE: My new set up.
Yep, the sub is definitely switched on (there's even a little green light that says so) I do get sound out of it and I've been playing with the settings and it shows up on the screen although the rear speakers showed up as large on the detection thing so I changed that to small (maybe because they're under the eaves or something) Just wondered if it was connected up incorrectly due to the W-3 error code on the initial set up using the supplied YPAO mic. It's probably the shape of my room that's messing the detection up and maybe something I'll just have to live with. Blu-Ray player will be the next purchase (which I think also just needs an HDMI and no optical?)
Just noticed I didn't reply to Robins post! The SkyHD box is set on Dolby (think the only other option available was mono) that was actually one of the first things I looked up.
Thank you to you both for your help so far.
__________________
RobinKidderminster
Online
RE: My new set up.
Sky hd needs to be connected thru av4 optical too as I mentioned.
__________________
BenLaw
BenLaw's picture
RE: My new set up.
Yes a blu ray player just needs hdmi.
I've just googled your error, sorry I misunderstood what you were saying before. I would try moving the sub somewhere else (maybe the middle of the room) to try and see IF setup can be completed without the error. If it is possible, then you can try a different sub position if at all possible. If you can't move it, run the setup without the sub and adjust the sub manually, although the error indicates you may not end up with the cleanest bass.
__________________
Steel_Lynx
RE: My new set up.
That's good news too then as I put the optical in to AV4!!
Sadly, the sub is pretty much stuck where it is so I will have to put up with it. There's lots of switches on the back so I will probably have a play with those and see what they actually do!
Thank you both for all of the help you've given, it is very much appreciated.
__________________
BenLaw
BenLaw's picture
RE: My new set up.
The reason I recommend moving it to do the setup is to see if it is possible to get it to work without an error. If this is impossible wherever you have the sub it may indicate that the mic or software is faulty, which you may be able to resolve with your retailer. If you can get it to work somewhere but have to put the sub back where it is you know there is some sort of local acoustic problem. You can then adjust the sub manually and do the best you can.
__________________
Steel_Lynx
RE: My new set up.
Well, I took the front grille off and turned the sub to a different angle and ran the test again and it all came out ok (sub said 100Hz on the test), I then turned it back to how it was but moved it forward about 5cm and again, it passed the test without any errors (although the sub said 80Hz this time and I don't really understand what that actually means in the grand scheme of things) It still says the surround speakers are large so I've changed that to small in the settings and changed the sub to 100hz (like I know what I'm doing lol) At least it's passed the test this time.
__________________
GSB
GSB's picture
RE: My new set up.
I think it is meaning the sub cross over and it is recommended to be set at 80hz:)
__________________
PanasonicTX-P46GT30B..Yamaha RX-A1010...Music Fidelity M3i...OPPO105EU...KEFR100/R200C/3001SE/HTB2SE...SkyHD2TB...QED Copper Speaker Cable /HDMI/Analogue...PS3...IPAD2
BenLaw
BenLaw's picture
RE: My new set up.
Your speakers should definitely be small. And given their size I think a crossover of 100 is sensible. You might even try 120.
__________________
GSB
GSB's picture
RE: My new set up.
rolling on the floor laughing I thought that THX recommended a cross over setting of 80hz?
__________________
BenLaw
BenLaw's picture
RE: My new set up.
It does, but those satellites are going to struggle at 80hz whereas another 20hz is unlikely to be much of a problem for the sub. No point sticking rigidly to the thx setup if it doesn't fit in with one's own kit.
__________________
GSB
GSB's picture
RE: My new set up.
Smile
__________________
