9 posts / 0 new
Last post
Pikman's picture
Last seen: 2 months 2 weeks ago
Moving TV to the wall - still have bookshelf speakers...
Very happy with our setup at present.
We have AE Evo2's along the front and QAcoustics 2010i's at the rear with BK Gemini Mk2 sub, which we rarely use.
The TV is now going to be wall mounted and so the speakers are going to need to be also (no other options). I am not sure what to do about this, the AE's are way too large for the wall.
I could replace them with the new QAcoustics 2010's and 2000C (about £200) but I fear they might still be too large.  Does anyone have any experience with this setup vs the smaller Q7000 (already double the price). I am sure it would certainly look nicer on the wall but am I correct in expecting a significant drop in sound quality?
Thanks in advance,
Pikman
simonlewis's picture
Last seen: 6 days 14 hours ago
RE: Moving TV to the wall - still have bookshelf speakers...
Thanks in advance,
Pikman
Not sure why you  feel you need to wall mount your speakers, i allways thought that speakers should be at ear height when sitting down, how high are you mounting your tv.
Pikman's picture
Pretty simple answer really, a toddler Smile
They aren't going to be mounted all that high but I do not think stands are too clever. Incdetally, they are on the hearth right now and it sounds fine - I always thought the same but a little angling and the brain is totally convinced.
TV is going above the fireplace and will be able to swing down a couple of feet. Not ideal but that is the plan!
RobinKidderminster's picture
Last seen: 1 month 2 weeks ago
My 30-somethings were toddlers once and my speakers never suffered. Maybe a solid basefor stands or are they on the floor/hearth? Interested tho in your 'TV swinging down'. Can you explain (for my daughters benefit).  :cheers:
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
Pikman's picture
I would share an image but I cannot simply upload one. The TV is on a small homemade stand on the hearth, just high enough for the centre speaker to sit beneath it and the 2 fronts just sit at the sides on the hearth again.
I'm worried that the TV will end up with some sort of toy imbedded in it Smile
This is the idea for the vertically swinging screen.
Pikman's picture
Edit: double post - that image verification thing on a forum is crazy :S
Check this link out pikman.
Thanks Pikman. The mount looks ideal. Cheers
Pikman's picture
Going back to this thread. The fireplace is coming out and the TV is going about half way up, good deal Smile
Still looking at the 7000's but right now we rarely have to have the sub on as the AE's go pretty low anyway. With the 7000's, is it going to be more or less necessary to have a sub active?
Log in to post comments
