M&K KX10 Subwoofer broken?
9 replies [Last post]
devo18uk1
devo18uk1's picture
Hi guys,
The title says it all really.  The sub appears to not be working. The power light doesn't come on when I switch it on so my first step is going to be to change the fuse in the plug.  If that doesn't work, any ideas what it could be?
Thanks in advance.
David@FrankHarvey
David@FrankHarvey's picture
RE: M&K KX10 Subwoofer broken?
It might be worth checking to see if there is any fuse that can be changed in the backplate. If not, unscrew the backplate and see if there are any on the board. If you get no joy, e-mail Ken Kreisel at kkreisel@kreiselsound.com, he may have the answers for you.
Smile
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
devo18uk1
devo18uk1's picture
Cheers for that David. Would this be the best person to contact about it's warranty as it's JUST still in it's 5 year warranty?
Chewy
Chewy's picture
M&K as a company don't exist anymore, MKSound did buy the rights to continue manufacturing M&K products, but I'm not sure they took on M&K's warranty liabilities.
I don't fancy your chances with a warranty claim, but if you don't manage to fix yourself, you could try MKSound to see if they will honour the warranty.
__________________
JVC X70 | Beamax 105" M-Tensioned Screen | Aerial Acoustics LR5's, CC5 and 4 x SR3's (7.2) | 2 x Paradigm Signature Sub 1's | Datasat RS20i | 3 x AB Systems 11000SE Monobloc amps + 6500SE 6-Channel amp | Oppo BDP-95 | NAD M50 | 24TB Synology 2413+| Netgear NeoTV 550 | PS3 | Darbee DVP5000 | Sonos Multi-room system
bigboss
bigboss's picture
The best person to contact first would be your retailer, where you bought the subwoofer from. Also, make sure you also send an email (not just telephonic conversation) so you have proof that you contacted your retailer before the warranty expired.
__________________
devo18uk1
devo18uk1's picture
Couple of issues have arisen. I have taken the back off of the sub to see if I could replace the fuse which is a T2A/250v fuse. When I got in there, I might as well have been trying to read Chinese.  I would attach a photo to see if anyone could help, but it doesn't look like I can do that.
Big Boss, I found the receipt from SSAV who only provided a 24 month warranty with the purchase even though M&K have a 5 year warranty, so I think I might be going down a dead end with that one as I bought it in September 2007, although I'll enquire all the same.
I will try and contact MK Sound and see if they have taken on M&K's warranties, if not, can anybody recommend a repair service in the Birmingham area?
Thanks again.
bigboss
bigboss's picture
Sevenoaks should have contacts & help you get it repaired under warranty.
__________________
devo18uk1
devo18uk1's picture
I have managed to find out that I can get it repaired under warranty apart from one minor issue, I don't have the original packaging.
I have the receipt for proof of purchase, so to me this sounds like a crock!
Anybody heard of anything like this before?
bigboss
bigboss's picture
You don't need the original packaging.
__________________
devo18uk1
devo18uk1's picture
Cheers BigBoss.
