Mixing speakers and ohm settings
1 reply [Last post]
ashton1
ashton1's picture
Good evening all,
Apologies in advance probably a really dumb question coming up.
I have an Onkyo 616 amp and mordaunt short alumni surround speakers.  I'm planning n upgrading the speakers over time and am looking to auction the Dali Zensor 1's to upgrade the surrounds.  First of all the front left and right.  Need to build a new tv unit as the centre speaker won't fit on my current stand.
The Dali's are 6ohms, where as my Mourdaunts run between 4-8. I've checked my amp settings which is currently at 6ohms.
Apart from possibly sounding a bit dodgy on my first upgrade I just wanted to check if there is anything else I should be aware of which could cause issues?
im presuming it will be fine.
Many thanks in advice
RobinKidderminster
RobinKidderminster's picture
RE: Mixing speakers and ohm settings
Yup. 6ohm is fine
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
