Living Room Home Cinema Project
6 replies [Last post]
DandyCobalt
DandyCobalt's picture
As moving home is out of the question, I got permission from Mrs C to make the most of the living room (which only measures about 4m x 3.5m), to turn it into a home cinema and music listening room.
But the provisos were that the tv must not be permanently in front of the window, and that if we change the seating, then it had to have a sofabed included (as short of spare rooms for roaming troubadours and swamp folk).
So, based on a recommendation here on the forum, I got a tv lift http://www.tv-lifts.co.uk/lifts.asp mount the tv on, so that I could move the tv and av rack in front of the window, and speakers to fire down the room...
IMG_3644
Then, got a great projection screen fitted by Kent Home Cinema (a 1.3 gain 2m wide Vutec Lectric 1) (not much chat on this forum about projection screens but this is a beauty - silent motor and great image) ...
http://www.kenthomecinema.co.uk/Vutec-Lectric-1-Electric-Screen.htm
So, ended up looking like this with the tv screen down...
IMG_3646
...and like this with the projection screen lowered (via 12v trigger on the HDMI 2 output assigned for the projector from the Pioneer a/v receiver)
IMG_3649
The screen is 2metres wide and copes very well with the long throw from the Sony HW15 projector.
__________________
Main: Pioneer tv + LX85, Sony HW15 Proj, Cyrus DAC XP+/Mono X300/CDXTSE2/PSXRx2, B&W CM8/CM1/PV1D, CA BD751, Virgin TiVo, Inspire Rega t/t, Benz Glider MC, EAR 834P phono amp; Slee Novo Headphone Amp
Second: Panasonic 42" E6B LED, Pioneer VSX-D2011, Kef eggs, Virgin TiVo
BenLaw
BenLaw's picture
Online
RE: Living Room Home Cinema Project
Seriously good job, nice one! Smile
__________________
HiFi   /   A/V   /   Bedroom
DandyCobalt
Thanks Ben, I've had to compromise on the position of the two "side" speakers, so they almost act as front wides, but given it's now a 9.1 system (including two boston acoustic cubes as front heights), I've done as best as I could in a traditional english front room with a fireplace taking up one of the sides.
(I don't know why the pictures are so small - but they get large if I click on them, hope does same for everyone else?)
__________________
michael hoy
michael hoy's picture
So, based on a recommendation here on the forum, I got a tv lift http://www.tv-lifts.co.uk/lifts.asp to mount the tv on, so that I could move the tv and av rack in front of the window, and speakers to fire down the room...
IMG_3644
IMG_3646
IMG_3649
Link to lift, your link includes the word to as part of the URL. Smile
__________________
AV System -  Panasonic 42VT30 ¦ MA Apex 5.1- 4xA10 1xA40+ AW-12 Sub ¦ Van Damme UP LCOFC Speaker Cable ¦ Pioneer SC-LX85 ¦ OPPO 95 ¦ Mark Grant G1500HD Precision audio cable ¦ Sky+ HD(1TB) ¦ Chord Active HDMI ¦ Belkin PF50 mains conditioner.
Bedroom - Sony KDL-40W2000 + Archos 7 streaming from Windows Home Server 2011, Altec Lansing inAir 5000.
Dining Room - Sonos S5.
Music - HP Proliant Server running WHS 2011 ¦ streaming FLAC to Sonos ZP90 and OPPO 95 via SC-LX85.
Hi Fi - Cyrus 8 XPd QX amp ¦ Cyrus PSX-R power supply acting as Pre Amp ¦ Quad 909 Power Amp ¦ Speakers - Spendor A3 ¦ Logitech Squeezebox Touch upgrade by Fidelity Audio ¦ power supply upgrade by Mains Cables R Us ¦ Power Plant Premier mains regenerator.
Controlled by – iPad2 and Harmony 1100.
GSB
GSB's picture
fantastic set up visualy...bet the sound is awsome rockin out
__________________
PanasonicTX-P46GT30B..Yamaha RX-A1010...Music Fidelity M3i...OPPO105EU...KEFR100/R200C/3001SE/HTB2SE...SkyHD2TB...QED Copper Speaker Cable /HDMI/Analogue...PS3...IPAD2
DandyCobalt
Sounds really great, particularly when I get a chance to play at higher levels. But being a semidetached house means that is fairly rare. Also means we have to be sensitive to s/w volume.
When the settee was being changed, the difference in acoustics when no settee was incredible - soft furnishings make such an impact to remove the echo/ reflected sounds.
__________________
GSB
GSB's picture
too true,i found a masive improvemant in my modest set-up when we changed from laminate to carpet.
__________________
