In wall / In ceiling speakers advice please...
No replies
pioneer7
pioneer7's picture
ohhh sure Hi all
I will be doing a refirb in our lounge soon which I will place on these forums from start to finish, False wall inset Tv LED Lighting etc I will be buying Q-Acoustics 2050 fronts these really are very good for the money and look very nice indeed they will be gloss white a 2000-c centre speaker to match, and a BK-Monolith again fo the money and qaulity very good indeed.
I will be instaling a 7.1 speaker set up future proof more than anything although there are not loads of movies in this format there are a few and they do sound excellent,  the fitting is not a problem as I will make custom housing for them, the problem is there are so many companies, many makes, very few if any reviews and as for deming very limited, so I thought I would ask if any of you good people have had any experience or indeed have this type of speaker installed, I realise price does vary alot but I see no need to go mad on the effect speakers but will not scrimp either.
I suspect I will have to take some risk in buying these speakers but I as say to see and dem is nearly impossible so any thought or input you can throw my way would be most welcome.
Amplification I have not decided yet but that should not matter to much.
Many Thanks
__________________
L-R Mordaunt Short Avant 153 in-walls. Avant 165 Centre in-wall. Performance Subwoofer. Pioneer BDP-450 Blu-ray Player. QED Cables Pioneer Amp[to buy]
Panasonic 50-GT50.Plasma
My system http://www.whathifi.com/forum/your-system/lounge-tart-uppt-1
