21 posts / 0 new
Last post
nugget2014's picture
Last seen: 1 day 20 hours ago
How loud is -20db?
Seen lot of people tend to watch films at -20db but how loud is this, around 90db I am guessing? Not too bad. Like having decent volume level on films when neighbor is out but want to know first, today I played pacific rim for 5 mins on 15 volume on my sony str-dn1040 using dali ikon sub mk2 and it blew a light bulb!
Setup: Samsung UE55JS8500, Samsung UBD-K8500 4K Player, Dali Zensor 3, Dali Vokal Centre, Denon AVR-X2200W, Arendal Sub 1, Monitor Audio Radius 45 Samsung S7 Edge
Hi-FiOutlaw's picture
Last seen: 10 hours 52 min ago
nugget2014 wrote:
Now imagine that you would got the Monolith instead... By now, You'll be seated in your neighbor's couch...Biggrin
Rega RP6/Goldring Elite MC>Clearaudio Basic Plus
Synology NAS>Auralic Vega>Pathos Classic One MKIII>Dynaudio X12
JamesMellor's picture
Last seen: 2 months 1 week ago
FFS Nugget are you trying to
FFS Nugget are you trying to knock the house down with it ? Biggrin
James
PS did you get the auto calibration sorted ?
Glacialpath's picture
Last seen: 4 months 4 weeks ago
nugget2014 wrote:
I used to listen at -25 on my amp but since I've done an auto set up and upgraded some of my cables I can now listen at -20.
For the size of you room mate I would have thought -25 would be fine. Up to you of course.
Hi-Fi: Campridge audio D500 SE, DACMagic 1, C500, P500.. Monitor Audio BR1 speakers.
H-T: Pioneer; Kuro LX5090, BDP LX71, SC LX73. CA P500. SKY+HD. Rel Q50. Mordaunt Short Avant.
Humm I tend to watch at -31
Humm I tend to watch at -31 to -37 which gives me dialogue at 50 to 60 dB's , that feels right , crash boom bangs are louder of course.
James
JamesMellor wrote:
James
nope, didnt Sad gonna take my mic in to RS and get a replacement.
davidf's picture
Online
Last seen: 3 days 6 hours ago
I generally watch around the
I generally watch around the -20dB mark - just seems comfortable for me - not too loud, but not too quiet either. Even if the neighbours go out, I don't edge it up much more than that, maybe -15dB tops.
The Little Audio Company
audioquest / audio technica / bluesound / chord co / cornered audio / golden ear / harman / innuos / jbl / kef / moon / ophidian / primare / revel / svs
might go for the third
might go for the third lightbulb tomorrow see if i can break it. lol, for films i have the gain on sub set to about 75-80%, along with the +10db on speaker settings along with 15-20 volume i bet the sub pumps out 90db
davidf's picture
Online
nugget2014 wrote:might go for
Is that +10dB on the speaker levels on the receiver?
yes on the receiver. only the sub though, the regular speakers are set to +0db. and the centre is set to 7db for clear vocals
grdunn123's picture
Last seen: 6 months 2 weeks ago
Then I'm not surprised you're
Then I'm not surprised you're blowing light bulbs! speakers will be next to go! wind those levels down some. I tend to be same as David, -20db for regular watching, crank it up a little for certain movies though.
Samsung 55Inch TV, Marantz SR 7009 Receiver, Panasonic 460 Blu Ray player, Monitor Audio Apex speakers, Monitor Audio GXW15 sub, Sky HD, Virgin Media 200MB BB, Sony Xperia Z3 phone + Z2 Tablet.
grdunn123 wrote:
so 70% gain and +0db on sub is ok for movies?
davidf's picture
Online
nugget2014 wrote:yes on the
Unless the centre speaker is particularly hard to drive (or the centre is maybe a sealed cabinet), there shouldn't really be a difference of 7dB between it and the front pair. This will give quite a focussed sound and drown out much of the sound produced by the rest of the speakers, which is fine for dialogue based movies, but not for anything with any effcts or ambience. I agree the centre should usually be boosted a little - I usually add 1dB to most auto setups, which seems to work nicely, but it shouldn't be so much more than the rest of the speakers.
As for the sub, if the level of the sub is too high on the receiver, it can overlaod the output and send a distorted signal to the sub when played at high volumes, so all your sub will be doing then is amplifying the distorted signal it is receiving. This in turn just draws attention to the sub.
BIGBERNARDBRESSLAW's picture
Last seen: 6 months 3 weeks ago
I'm just glad I don't live
I'm just glad I don't live next to any of you guys, especially Nuggett. I tend to watch tv at -30 to -40, but with the dialogue level raised to +3. I watch DVDs and Blu Rays without the dialogue level raised, but still only on around -25 to -35. Since buying the Zensor 3s, I no longer bother using the sub.
Panasonic TX-P50GT50 / Yamaha RX-A2020 / Panasonic DMP-BDT110 / Dali Zensor 3 / Dali Zensor Vokal / Mordaunt Short MS20i Pearl Edition / Cambridge Audio Minx 11 / Tannoy TS2.10 / Roksan Radius 5.2 / Ortofon Super OM 20
I have re calibrated and it
I have re calibrated and it worked for the sub this time with gain set to max so it can hear it. Still too noisy it says though but no error for the sub anymore. Set centre to +5 instead of 7 see how it sounds. Set sub to +0db see how it sound also for movies. I think for music I would have it turned off at that volume of the sub though doesn't add that much
messed around with settings
messed around with settings and the centre at +2db now i can hear volume good! must have changed after intergrating the sub into my system.
the sub set to +0 didnt sound that great so i turned it to +6 but it was quite bassy so turned it down to +4db, see how it goes.
Pages
Log in to post comments
