Home Theater System Upgrade
4 replies [Last post]
Bryan Steven
Bryan Steven's picture
Hi.  My current 3 year-old HT set-up consists of:
Onkyo TX-SR606 receiver
Panasonic DMP-BD35 blu-ray player
Dali Ikon 6 front speakers
Dali Ikon Vokal 2 center speaker
Dali Concept 1 rear speakers
Dalik Ikon subwoofer
Panasonic AX-200 projector
Da-Lite 106" fixed screen
Ecosse CS4.45 speaker cables, Van del Hul Flat HDMI cable, Tacima CS929 mains
I'm thinking of doing a gradual upgrade of my system by replacing my receiver, blu-ray player, and projector with Onkyo TX-NR818, Panasonic DMP-BDT210, and Panasonic PT-AR100U. My questions are as follows:
1. Will the NR818's characteristic match with my Dali speakers? (I'm not sure if it has the same characteristic as the 606 even if both of them are Onkyos.)
2. Is the BDT210 considered a good upgrade from BD35? Or should I go for the BDT310 or another brand/model instead?
3. Is the AR100U going to produce a significantly far better picture than the AX200 considering the former is 1080p and the latter is 720p? (My viewing distance is approx. 15 feet)
4. Since I'll be buying each component one at a time over 6-12 months, in what order would you suggest do I buy them (cost notwithstanding)?
Thanks a lot.
Bryan Steven
David@FrankHarvey
David@FrankHarvey's picture
RE: Home Theater System Upgrade
The Onkyo 818 should work fine with your Dali's, and it's Audyssey XT32 should sort out any room issue you have, much better than the version of Audyssey on your 606. It will also EQ the subwoofer frequencies, which many receivers don't do.
Your Bluray player is still pretty decent (I still have a BD60 in action), so I'd update the receiver first, as this will make the biggest difference to your system.
Are you in the US Bryan? I only ask as I found that projector on Amazon.com. Im assuming you are for now.
That model seems more like a data projector based on its lumens output, which seems rather high for a home cinema based PJ. Alternatively, have a look at the Mitsubishi HC3800 and the Epson 8100, both of which will be much quieter, and look far less washed out. As you already have HD in the form of 720, the difference jumping up to 1080p won't be as great as it was when you jumped from standard def to 720. But, the bigger the screen, the more you'll notice the difference. The PJ's you're looking at will be fine up to about 7-8ft, although more modern PJ's tend to have technology on board that fills in the black gaps between pixels (on LCD's). Digital PJ's (DLP, DiLA, SXRD etc) don't tend to suffer from this, but can look a little softer as a result.
Whether you update the receiver or PJ first will really depend on which you feel is more important to you - audio or visual.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
Bryan Steven
Hi, Frank.
Thank you so much for your valuable inputs. They were very useful in helping sort out which decision I should take. I shall then get the 818 and look at other PJ options you mentioned.
Yes, I'm from the US. New york to be exact.  Smile
Regards.
David@FrankHarvey
Its David Smile
Unless you're looking to use the PJ in a well lit office, ignore anything above 2000 lumens. Most dedicated home theatre PJ's are usually around 1000-1500 lumens (give or take), and 3D PJ's whose 3D glasses loses some brightness when used can be up to 2000 (even 2200 in the case of some Epson models). So use this number as a guide, but the other number to cross reference is the noise level figure. Home theatre PJ's are now usually less than 28dB, although that is a little high by today's standards, so try and find something less than 25dB for something that'll be less annoying during quiet bits Smile
__________________
willsonandy
willsonandy's picture
Have a nice content!! I like this pose for that home theater system upgrade issue. help, I`m sinking It contains trully good and educative info. Thanks! houston home automation
