3 posts / 0 new
Last post
admin's picture
Last seen: 1 day 17 hours ago
home cinema set 2500 pounds
Because i like music more on my headphone, I want a full 5.1 system for movies and some background spotify via apple tv.
The room is medium sized 30 m2
I like to buy a svs or bk sub and some nice 5.0 system.
Any advice?
Cheerd
George
davidf's picture
Last seen: 16 hours 11 min ago
RE: home cinema set 2500 pounds
Do you like music more via your headphones because you've not heard a good enough hi-fi system, or just because you prefer the sound of headphones?
the little audio company, birmingham
audioquest / audio technica / amphion / bluesound / chord co / cornered audio / elipson / golden ear / innuos / jbl / kef / moon / ophidian / primare / revel / svs
davidf's picture
That's a fairly large room to fill, and what will be needed to fill that room will depend on the volume levels you require. The bigger the sub the better, so something like the SVS PB12 NSD will do the trick. You'd be looking at receivers around the £1k mark, so check out the Onkyo 818, which will make the most of almost any speaker package with Audyssey's XT32 room EQ, currently one of the best available. If you can catch an outgoing model like the Pioneer SCLX75, Yamaha RXA2010 or equivalent, you'll get more out of whichever speaker package you choose. For speakers, try Monitor Audio's Bronze BX2's. If you can house it, try and use a BX2 as a centre too, which will help keep your soundfield more consistent, and will outperform the matching Bronze centre.
Log in to post comments
