Help with Budget HD - Have Projector and SkyHD but no Amp, Speakers, DVD...
4 replies [Last post]
Andy Wright
Andy Wright's picture
First of all I apologise for my ignorance, but I've seen such good responses and I don't have the cash to use trial and error for this. WHAT I HAVE - Infocus IN76 (720p native) & SkyHD, AppleTV (not yet but soon I think) I have a terrible room unfortunately, but I can't change that and am trying to get best out of it WHAT I NEED - 5.1 Surround - considering Tannoy EFX 5.1 or something else smallish Plus - An Amp obviously - currently have no idea (don't need high output - due to neighbours upstairs) And - something to play movies (want Dolby Digital and DTS), I have no idea if I should get Blu-ray or HD DVD now or wait Cabling ? Usage - 40% sport (mostly HD), 40% movies, 20% music Have been v. happy in past with Marantz & Nad - but that was a while back All opinions and advice very gratefully received.
Andrew Everard
Andrew Everard's picture
Re: Help with Budget HD - Have Projector and SkyHD but no Amp, S
If you're looking at speakers at that level I guess the budget is very tight indeed: I'd suggest Onkyo TX-SR505 receiver and Toshiba SD-370 DVD player.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
Clare Newsome
Clare Newsome's picture
The separates-route Andrew (morning!) suggests will give you the best performance-per-pound, but if you're looking for tiny speakers, Sony's new
DAV-IS10 home cinema system would give you REALLY small speakers, sub, amplifcation and upscaled DVD playback for £600.
We're testing it - and a range of other one-box kit - in our October issue, out August 23rd
__________________
Group PR Manager - Computers Unlimited;
Former Group Editor of What Hi-Fi? Sound and Vision and Whathifi.com
Twitter: @ClareNewsome
Andy Wright
Thanks for your help, I'll check out the reviews on these suggestions, and I'll be looking forward to the next issue
gabs.3544
gabs.3544's picture
Depending how much money you got is everything. what might be a little to somebody is loads to you. Look at the onkyo txsr 505 receiver if you got £250 put away for it. I also got my Toshiba hde1 HD DVD player for £240 off the net aswell. Never looked back mate. I dont care about the format war that people worry about. There is good films on both sides and what you can't by on HD DVD you can rent and upscale it in your HD player. Good luck mate.
