Help, choosing 5.1 set for movies
No replies
fedmond31
fedmond31's picture
Hello, need advice on best choice between HC speaker sets,
The room is 20m2, AVR is Denon 1911, Main task is low volume movies with highest priority on clarity of dialogues.
Due to budget and Center speaker size limit of 170mm H X 460mm W, My selection is between these front scenes:
Dali Zensor Vokal + Zensor1
Klipsch Ref RC42II + RB41
Monitor audio Bronze BX center + BR1 or BR2
Wharfedale 10CC +10.1
I will get Surrounds + Sub according.
I am open to any other suggestions around 1000£ for the 5.1 set.
Thanks a lot.
Hello, need advice on best choice between HC speaker sets,the room is 20m2, AVR is Denon 1911, main task is low volume movies with highest priority on clarity of dialogues
.Due to budget and Center speaker size limit of 170mm H X 460mm W, My selection is between these front scenes:
I will get Surrounds + Sub according.I am open to any other suggestions around 1000£ for the 5.1 set.Thanks a lot.
