HELP AUDIO RETURN BENEFITS AND HOW TO USE IT
6 replies [Last post]
gazman3510
gazman3510's picture
No replies
http://css.cdn.whathifi.com/sites/whathifi.com/modules/whathifi_advanced...); background-attachment: initial; background-origin: initial; background-clip: initial; background-color: initial; background-position: 50% 0%; background-repeat: repeat no-repeat; padding: 0px;">
 Online
Hi can someone explain in the simplest terms what is audio return how do I use it anthe benefits I have a Sony BDPS 790 bluray player a ONKYO TXNR 609 receiver
My tv is a Philips 50pfp5532d cables I will be using are audioquest pearl I know that my plasma tv is an older generation set dose that preclude me from being able to use the audio return feature I am a bit vague about this
relocated
relocated's picture
RE: HELP AUDIO RETURN BENEFITS AND HOW TO USE IT
It is unlikely you have ARC on your tv but you never know.  Check the handbook for your tv and see if one of the HDMI inputs is marked ARC or spin the set round and see if any HDMI inputs are similarly marked up.
__________________
Apple Lossless - ATV3 - AVI ADM 40  or  Marantz CD50SE (modded] - AVI ADM 40
also ATV3 into AVI ADM 9T [my wife's system] and Grado SR80i
gazman3510
Thanks I don't think the hdmi on my tv is marked as ARC but is there any other way to use audio channel return feature and can you explain exactly what audio channel return is and how to use it
Thanks in advance
Gaz
frodo1
frodo1's picture
Your plasma is very old and so it doesn't support the ARC.
Only televisions from around 2010 and towards support ARC.
You must use digital coaxial cable or stereo RCA cinch cable if
you want to connect the sound from your TV to the Onkyo.
Andy Madden
Andy Madden's picture
Hi gazman,
an ARC enables you to send audio from your TV's ARC-enabled HDMI input into your home cinema amp, thus bypassing your TV's speakers. Another benefit is that it saves you running extra cables (either a digital cable or pair of analogue interconnects) into your home cinema amp. With ARC, you just need the one HDMI cable.
__________________
Reviews Editor, What Hi-Fi? Sound and Vision & whathifi.com
gazman3510
Thanks Andy I understand now much appreciated
relocated
relocated's picture
With ARC, as has been said, you get to connect things up more simply with one sort of cable.
You also get around the B>S> of cable preferences to supply your TV based sound because an HDMI compliant cable will do it all without any differences to sound quality.  No more angst about expensive cables.
__________________
