22 posts / 0 new
Last post
nugget2014's picture
Last seen: 2 weeks 5 days ago
Further upgrading my home cinema system, what to buy next?
Come into a (little) bit of money selling few things on ebay that are of no use to me anymore and going to use the money for home cinema upgrades theres a few options for me here.
Do i get surrounds, making my setup a 5.0 (cambridge audio minx min11) unless i can justifying upgrading to min21
Do i get a subwoofer (most likely bk monolith)
Do i save for a bit longer and get the floorstanders i am most excited in? (MA bronze bx6) going to try out a few other speakers along that price point, dali zensor 7 and b&w 685 s2
what are you thoughts on the b&w cm1's compared to the newer 685 s2's?
i love my bass and i tried using pure direct on my sony str-dn1040 ac receiver and i did not like it at all, hardly noticed any bass there! i'll stick to my +10 bass eq only good for artists like taylor swift where you dont care about bass i wouldnt mind having a pair of floorstanders so i wouldnt need to eq the bass. how is the soundstage and bass on both the b&w speakers?
room is about 14 by 12ft cant upload picture as its buggy and stretches horribly.
going to sell my v moda m100 headphones and use the money towards more budget for upgrade. Smile
Setup: Samsung UE55JS8500, Samsung UBD-K8500 4K Player, Dali Zensor 3, Dali Vokal Centre, Denon AVR-X2200W, Arendal Sub 1, Monitor Audio Radius 45, Elac Debut Atmos
bigboss's picture
Last seen: 1 week 3 days ago
Without a shred of doubt, a
Without a shred of doubt, a subwoofer. It's not just about thumps, the soundstage suddenly becomes lively. It's the singlemost speaker that makes maximum impact to your home cinema experience. You don't need floorstanders for bass. Leave it to the specialist (subwoofer).
bigboss wrote:
i still would need floorstanders or better speakers in the future as then i'd turn sub off for music as i have music on many hours a day and i think neighbours would try to kill me..although bass doesnt go that low for music and not often anyway just a big thump of the room so maybe its not as bad for neighbours for music? as when i had a demo i THINK the room shakes and things vibrate with the extended low bass notes of films but music is quick thump am i right or wrong in saying music bass wont be felt/heard as much as movie bass? at a reasonable volume of course
bigboss's picture
It is a myth that
It is a myth that floorstanders are better. Theres no reason why floorstanders should perform better with bass notes than subwoofer when it comes to music. Subwoofer isn't about the thump when properly set up. You should be alright with neighbours.
plastic penguin's picture
Last seen: 11 hours 12 min ago
nugget2014 wrote:
BB is right. Bigger doesn't necessarily mean better. Floorstanders have certain qualities that smaller standmounts don't have, and vice versa.
If you're hearing the occasional thump, subject to interpreration, then you are either cranking up the volume too high or your current speakers aren't right for your room size or amp.
Given how far the speakers are placed apart I would avoid floorstanders like the plague. You will never hear the best the amp can give. For EDITED sake go and try some little Tannoys at Richer Sounds. You might be surprised. They'll work a treat with Sony amps.
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
jonathanRD's picture
Last seen: 20 hours 7 min ago
Hi Nugget, having followed your threads and seen the early photos of the room in your new flat, I was a little surprised that you put your tv and speakers against the wall adjacent to the doorway. Did you consider putting them against the opposite wall where you can widen the soundstage? I agree with others that floorstanders may be 'too much' in your room, and especially if placed where your current speakers are located.
From memory I think you also have altered your focus from just home cinema to music as well, so if floorstanders are not going to work, a well integrated sub maybe a better option, and this then may rule out the BK Monolith as it is best for music, as far as BK subs go, the XXLS400 would then be a better option. I have the 400 in a room 5m x 4m and I am more than happy with it for both cinema and music. At night I often turn the sub off when listening to music so I don't disturb others in the house. As you are in a flat with neighbours below you, this might be a better option (as you cant turn the base off floorstanders without tone controls).
Can your system go against another (wider) wall?
Rega Apollo > Exposure 3010S2D pre & 2 x 3010S2 power > RS5
Sony BDP S480 Onkyo TX-NR609 MA BX1, BX2,Centre,BXFX BK XXLS400DF
Glacialpath's picture
Last seen: 7 months 6 days ago
Hi there.
Hi there.
What is the subfllor of your flat? Also what is the construction of the adjacent walls to your neighbours? I live in a first floor flat. I'm on the end but I have someone on one side and one below. They can't hear my movies or music unless they are dead quiet and then they can only barely hear it.
I have my films and music loud. The floor constrution in my flat is 12inch thick concrete and the wall joining me to the flat nextdoor is a cavity brick wall.
I'm very lucky in that respect but if your flat is built the same way then you will be fine leaving a sub on for music. As other people have said a subwoofer is not to add bass but to add/allow the weight of the sound/music to be replicated in full. Speakers alone can't do it even if they have a great bass responce. I would keep saving your money and do justice to your AVR buy getting what is needed to 5.1
Hi-Fi: Campridge audio D500 SE, DACMagic 1, C500, P500.. Monitor Audio BR1 speakers.
H-T: Pioneer; Kuro LX5090, BDP LX71, SC LX73. CA P500. SKY+HD. Rel Q50. Mordaunt Short Avant.
the other side of room with slightly bigger area (goes into an alcove) but theres a radiator there which if wasnt there i would of swapped the setup around but dont think it's possible.
if floorstanders are not the best option for my room then what price of speaker would i have to pay to get a better sound quality+bass+soundstage?
Glacialpath wrote:
Glacialpath wrote:
Hi there.
i have carpet with underlay over wooden floorboards. the neighbour underneath me is the only one that can hear my music (if he ever has) as the room directly behind the tv is my kitchen, the room behind the kitchen is upstairs neighbours so i dont think its possible for them to hear it.
bigboss's picture
Now that you're not even
Now that you're not even acknowledging the suggestion of adding a sub, I'll say this for one last time & I'm out.
For better results from your existing speakers (and before you waste more money on different speakers), get a sub (they also have a try at home policy) and set your speakers to "small".
That way, the lower frequencies will be diverted to the sub which can handle them the best. Your existing speakers won't have to concentrate on those lower frequencies, and therefore do justice to other frequencies. Your system will sing.
That's all I have to say. I'm out.
sorry bigboss, i forgot to quote saying that i AM getting a sub, infact i decided that i'll get a sub next before anything else.  although i have yet to decide on a model
sorry bigboss, i forgot to quote saying that i AM getting a sub, infact i decided that i'll get a sub next before anything else.  although i have yet to decide on a model thanks for your advice
bigboss's picture
Do one thing at a time, so
Drinks
Do one thing at a time, so you know what gives the maximum impact. Get a sub first, and then see if anything else needs changing.
bigboss wrote:
bigboss wrote:
Drinks
yeah, although even after i get a sub in the future i will most likely upgrade my fronts anyway as i tend to get an upgrade every so often as i always want to improve. if not floorstanders then some better standmount's. although thats last on my list as surrounds after the sub. may also get some doly atmos speaker things to put ontop of my dali zensor 3's (thats if sony 1040 gets firmware update to support atmos..)
Re: Getting a sub
When you decide on a sub because you have floorboards you'll want to isolate the subwoofer from the floor. Either spikes or some other method.
Thant's good you have 2 kitchens for the sound to travel through before your next door neighbout hears it. Shame about the radiator. Can it be moved?
Sounds like you need to learn quite a bit before spending too much. You got the bug for sure but as BigBoss says, one thing at a time. We are all learning of course. If you learn all the steps to get the best out of what you currently have then you will be better prepared to set up any new kit you get.
Here's an option. Would you be able to set you kit up in the corner it is currently in on a diagonal instead of up against the corner?
bigboss's picture
nugget2014 wrote:
Unlikely. It's 7.2 channel; you need 9.2 for effective Atmos (although 5.1.2 is possible). Only future receivers will be Atmos enabled.
Pages
Log in to post comments
