Front L & R channel distance for HT???
4 replies [Last post]
atkins4725
atkins4725's picture
Evening all,
Just having a play about with my front L & R channels in my HT and can't quite decide what distance to have them apart. Is it best to try get them as far apart as possible
__________________
Philips 56PFL9954H, Sky HD, Marantz SR 7005, CA 751bd, Monitor audio Apex, Chord Prodac, Chord active HDMI's, Chord chorus 2, Chord odyssey 2, Atacama equinox rack.
DandyCobalt
DandyCobalt's picture
RE: Front L & R channel distance for HT???
I suppose it depends on the size/width of your room and how far you are from them (in the magic triangle). My CM8s are about 2m apart, with listening position at about 2.6m from them...if that helps.  Had to play with the toeing-in to find best sound.
__________________
Main: Pioneer tv + LX85, Sony HW15 Proj, Cyrus DAC XP+/Mono X300/CDXTSE2/PSXRx2, B&W CM8/CM1/PV1D, CA BD751, Virgin TiVo, Inspire Rega t/t, Benz Glider MC, EAR 834P phono amp; Slee Novo Headphone Amp
Second: Panasonic 42" E6B LED, Pioneer VSX-D2011, Kef eggs, Virgin TiVo
toyota man
toyota man's picture
Good question I have no idea but I am sure somone on this forum will know:) Smile
__________________
atkins4725
Thanks for the reply,
Ive moved them further apart considerably and it has seemed to open up the sound much more. I was worried that to much distance apart would massively reduce the lower end (still saving for the sub) however, low end is still very much here, thankfully.
__________________
scene
scene's picture
Dolby and THX recommend specific placement for l&r speakers, and rear ones, in a 5.1 setup. They go for the angle between straight ahead being between 22 and 30 degrees, for dolby and 22.5 degrees for thx. What this means, is lots of time with a calculator and trigonometry (or pythagoras' theorem) or just thinking that for every 2m the speakers are apart, your listening position should be between 1.5-1.75m - if you go with their rationale. For your listening distance, of 2.6m, this would mean placing the speakers about 3m to 3.5m apart. If you were just going for pure stereo as well as 5.1 or 7.1 I'd go nearer the lower figure. These are guidelines only, and what sounds best to you is key.
__________________
Hi Fi: Arcam A85, DV88 (CD only), Project Debut II, AE Compact-1. AV: Arcam AVR250, DV79, Sony BDP-S760, Monitor Audio Silver 8i, RS-LCR, RXFX, Sonos ZP90, Pioneer KRP500A. 2nd AV: Pioneer SX-SWR2, Dell Zino HD, KEF KHT2005.2 eggs, Sonos ZP90. That Cable HDMI, Chord Crimsons and Sonos ZPS5s everywhere & a spare Yamaha RXV-667!
