cinema dillema
8 replies [Last post]
lanks76
lanks76's picture
I have a dillema which is this what is the best value home cinema amp at present i only have budget up to £400 and will need speakers within that budget. The best i have seen is the yamaha yht196 which comes with all speakers and cables but if i got better amp i could get speakers off well known auction site . Of which my amp cd and tuner came from.
__________________
Denon pma-255uk, Denon dcd615cd, Denon tu260l tuner, Tannoy mecury F2 apple Ipod dock with cambridge audio cable's .
bigboss
bigboss's picture
RE: cinema dillema
__________________
lanks76
lanks76's picture
RE: cinema dillema
Some nice options there thank you
__________________
duaplex
duaplex's picture
RE: cinema dillema
Would you consider a used amp?
__________________
Panasonic 65" 3D TV (P65VT50), Pioneer LX83, CA, Azur 751BD, PS3, Water Cooled Xbox 360 (Modded), Nintendo Wii U, Sky HD+, i7 PC overclocked with 6850 HD Radeon, CM8 Fronts (Bi-Amped), CMC Center (Bi-Wired), DS3 Dipoles, PV1 Sub. Van Den Hul M.C. Snowtrack >Halogen Free< wiring, Chord Active Silver HDMI's, Cabridge Audio AUD700 Analogues Interconnects, QED Signature Subwoofer cables, Chunky Monkey custom oak AV cabinet.
duaplex
duaplex's picture
RE: cinema dillema
__________________
BIGBERNARDBRESSLAW
BIGBERNARDBRESSLAW's picture
RE: cinema dillema
__________________
LOUNGE:  PANASONIC TX-P50GT50 / PANASONIC DMP-BDT120 / SKY HD / SONY STR-DA2400ES / Q ACOUSTICS 2020i (front) / Q ACOUSTICS 2020 (rear) / Q ACOUSTICS 2000Ci / Q ACOUSTICS 1000Si / PRO-JECT DEBUT 3 / WD MY BOOK LIVE
BEDROOM:  SAMSUNG LE32C450 / SONY BDP-S360 / ECHOSTAR HDS-600RS
duaplex
duaplex's picture
RE: cinema dillema
Ah, i was confused with the second part of the post talking about eBay.
In that case, as BB suggested.
__________________
Always cut the ...
Always cut the red wire!'s picture
RE: cinema dillema
Why buy the Sevenoaks for £350, new or used, when you can buy it for £250 from Richer Sounds?
not shooting you down, just thought everyone on here would be on the ball with deals, especially from RS.
Defo a no brainier buy at that price.
lanks76
lanks76's picture
RE: cinema dillema
Some good options i would consider used as my hifi wss from the bay i have used richers before just been out of loop for a while
I have a processor again from ebay and was sctually an accidental purchase but has no remote or output for sub !!
__________________
