9 posts / 0 new
Last post
davlee's picture
Last seen: 3 years 9 months ago
Centre Speaker - inbuilt or not
I am having a cabinet built to house some home theatre equipment. Should I leave the centre speaker compartment open at the rear? It will house a Focal 1028be series centre speaker.
BenLaw's picture
Last seen: 1 year 11 months ago
RE: Centre Speaker - inbuilt or not
Where else would you run the speaker cable?
I am the danger.
RobinKidderminster's picture
Last seen: 2 months 3 weeks ago
If the centre is rear ported then yes. Use some thin material behind if it looks 'messy'. Otherwise the sides will have more effect so ensure (anyway) that the front is flush or proud of the front of the cabinet. What r yr speakers?
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
davlee's picture
Fronts & centre are Focal 1028be
bigboss's picture
Last seen: 17 hours 26 min ago
As long as you can get the cables in for connecting to the speaker, a closed back should be ok. Even my speakers are enclosed in cabinets. Just make sure the speaker is placed right at the front, to prevent booming due to the cabinet.
BenLaw's picture
They're rear ported so I'm not sure I agree. I don't get the argument for keeping it closed, the speaker itself will hide the view of any wires.
I am the danger.
My previous rear ported centre sounded boomy in a closwd back cabinet but my current closed mezzo is fine. I previosly used a bung or eq to negate the effect. May depend if the front is closed like an in wall speaker or the centre is sitting in a smallish closwd box, as mine is.
We frequently hear that a speaker needs to breath!
bigboss's picture
As long as there's a 6-inch gap behind for a rear ported speaker, shouldn't it be ok?
http://thespeakerguys.blogspot.co.uk/2008/02/rear-ported-vs-front-ported-speakers.html
I suppose it's best to experiment with different placements to make sure there is no detrimental effect on sound.
BenLaw's picture
I wouldn't fancy it personally, but then I don't like ports at all. As you say, experimentation is required.
I am the danger.
Log in to post comments
