2 posts / 0 new
Last post
Dan Fahey's picture
Last seen: 8 months 5 days ago
Can anyone recommend a ceiling mount for a projector that doesn't have lens shift
Hi - I bought the Epson TW6100 projector last week - great reviews but it doesnt' have vertical lens shift.  I am going to ceiling mount it but the projector mount they sell (which is only available in white) - the  will not help with my vertical lens shift problem.  It will be mounted directly in front of the screen - there are no light fixtures in the way as it  will be a dedicated cinema room.
Could anyone recommend a better mount for this projector?
ideal av's picture
Last seen: 1 month 3 weeks ago
i`d recommend the premier
i`d recommend the premier mount spi ext, it has an adjustable as well as removeable drop pole and i`ve used it a lot with Epsons
Allan yes
Log in to post comments
