Can a voltage converter/transformer be used with a 110v Onkyo AVR
6 replies [Last post]
Ralph993
Ralph993's picture
GF is moving over from Canada and has an Onkyo TX-NR809 but it uses 110v power and we 220v over here. I have a transformer, would it be safe to use one on an AVR so that it can run on 220v? Any advice appreciated
Juzzie Wuzzie
Juzzie Wuzzie's picture
one view
Sell it, buy something new here.  Once you factor in hassle and faff factor, it is probably a break even trade.  Additionally, and I'm guessing here, the size of accommodation you'll have here will be smaller than in Canada, so that might change the approach you would take to home cinema.
__________________
Living Room: Samsung 40C7000; Oppo BDP-103EU; Onkyo SR308; Apple TV3; Airport Express; Sky HD+; Jamo A102 HSC5; Naim Nait 5i-2; Neat Iotas; Chord / Wireworld / QED / TCI interconnects and speaker wire; Harmony 550 universal remote; Tacima mains conditioner Portable: Shuffle (1G); iPad (1G); iPad Minil FiiO E1; AKG450; Grado SR60i; Sennheiser CX300II; custom Ultimate Ears Car: iPod Classic 120GB
Andrew Everard
Andrew Everard's picture
RE: Voltage converter/transformer 110v Onkyo AVR
Provided the transformer has sufficient capacity for the Onkyo – it's rated at about 900W peak consumption, or 7.5A/120V – it should be fine.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
Ralph993
Ralph993's picture
RE: Can a voltage converter/transformer be used with a 110v AVR
The room is 12m x 6m so not exactly small...
Thanks for the input on the transformer sizing, I'll be sure to check on that
Juzzie Wuzzie
Not exactly - about 20m2 bigger than my whole flat!
__________________
bigboss
bigboss's picture
RE: one view
Never assume anything. Smile
__________________
chudleighpaul
chudleighpaul's picture
RE: one view
The Canadian mains is 60hz so even if you had a transformer it is possible that you would have problems with a 50hz supply over here. Best advice is sell it and buy new here.
