5 posts / 0 new
Last post
smarky's picture
Last seen: 3 years 3 months ago
Bose Solo Sound System
Hi,Had a demo of this at PC World tonight, seemed very impressive is that the case?.
toyota man's picture
Last seen: 2 months 3 weeks ago
RE: Bose Solo Sound System
Hi smarky I am thinking of getting one for my tv in my bedroom so I will have a dem soon
Musical Fidelity M6500i, Musical Fidelity M6 CDP, Musical Fidelity Encore Connect, ATC SCM 40s, Cord Chameleon plus XLRs, Tellurium Q Black speaker cables.
bigboss's picture
Last seen: 3 days 9 hours ago
Review here:
http://www.whathifi.com/review/bose-solo
I have read review and to be honest I think for my bedroom It will fit the bill but I will have a listen  :cheers:
davidf's picture
Last seen: 3 days 4 hours ago
The Solo is intended to be an extremely simple product that anybody can set up and use. I think WHF's 'against' of limited inputs is a bit unfair as the intention isn't to plug all of your sources into it - your sources all plug into your TV as they normally would, so there's no unplugging products and having to wire them back up again. All that is needed it to place it under your TV,  plug it in the mains, connect it to your TV's analogue or optical digital output, and you're done!
As for sound quality, sure you can get a pair of speakers and an amp that will probably sound better. but it is clearer, fuller, and more intelligible than the TV's speakers, which is the whole point of the product. Its either this or a cheap Yamaha sound bar.
the little audio company, birmingham
audioquest / audio technica / amphion / bluesound / chord co / cornered audio / elipson / golden ear / innuos / jbl / kef / moon / ophidian / primare / revel / svs
Log in to post comments
