Bipole/dipole speaker placement
2 replies [Last post]
quad-gradientsetup
quad-gradientsetup's picture
banging head against wall
Hi all,
Im looking at the monitor audio silver sxfx surrounds to use in my 5.1 set up. I'm just a bit confused as to their positioning. They can be switched between bipole to dipole for flexibility. Some say side walls others say rear walls. My listening position is close to the rear wall about a foot away. Not sure if that makes a difference to their placement.
Any tips or advise would be most welcomed.…
David@FrankHarvey
David@FrankHarvey's picture
RE: Bipole/dipole speaker placement
Dipole speakers on side walls should be at least 1-1.5m away from the rear wall - the further the better. The closer they are, the more HF reflection you'll get off the back wall, drawing attention to their position.
Rear placement should be set to bipole.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
quad-gradientsetup
Thanks for that FrankHarvey.
I haven't got that 1m on the side walls to bring them away from the rear wall. So I guess I just mount them on the rear wall in bipole . As my seating position is only about a foot away from the rear wall how far apart should I mount them and how high from the floor should they be…?
Thanks again for your reply…
