Best Sound Home Cinema??
16 replies [Last post]
Englishbull
Englishbull's picture
__________________
Pioneer KRP-500 > Onkyo SR605 > Tannoy Arena > PS3.
Englishbull
RE: Best Sound Home Cinema??
ERR first post never posts!! banging head against wall banging head against wall
Hi
Just wanted to ask the experts if i am getting the best sound from my Home Cinema.
My AV is a Onkyo SR605 Blu rays played through PS3.
HDMI cable used for picture and sound is via Optical Cable.
Now when i play a Blu ray the Amp automaticly switches to Dolby Digital (little red icon appears on the LED screen onthe AMP). Now this does sound very good when watching a film. But there are options o the AMP that states TRUE HD and PURE AUDIO. If these are selected i dont think it sounds as good.
Does anyone have this AMP? Any suggestions on improving the sound?
thanks
__________________
Chewy
Chewy's picture
Ditch the optical cable; HD audio codecs are available over HDMI only!
__________________
JVC X70 | Beamax 105" M-Tensioned Screen | PMC MB2i Fronts & MK SS150 Surrounds (7.1) | Paradigm Signature Sub 1 | Primare SP32 | 3 x AB Systems 11000SE Monobloc amps + 6500SE 6-Channel amp | Oppo BDP-95 | UnRaid 16TB Media Server | Netgear NeoTV 550 | PS3 | Darbee DVP5000 | Sonos Multi-room system
bigboss
bigboss's picture
Online
Agreed. Go with HDMI for audio as well. By the way, which PS3 model is it? If PS3 fat, it can't bitstream audio to your receiver. The PS3 will decode HD codecs as well, but that little red icon on your amp will not light up, as it has received already processed sound from the PS3. The light will come on only when your amp does the job. PS3 slim can bitstream audio as well.
__________________
Englishbull
Cheers for the info, I'll give it a go today and see how I get on.
__________________
Englishbull
Hi
yes it is the fat PS3,  Is this no good then??
Forgive my thickness here i'm normally ok at setting up but seem to be having problems.  The current set up is as follows
Sky - HDMI to TV (picture) Optical to AMP (sound)
PS3 - HDM to TV (picture) Optical to AMP (sound)
How to i connect the PS3 to the AMP with HDMI for both?
The AMP has 2 HDMI IN and 1 Out sockets, Will i need another HDMI cable?
Cheers for any help.
__________________
AndyWright
AndyWright's picture
Hi EnglishBull, You can try disconnecting the optical cable from the PS3 jus send the sound to the amp via the Hdmi cable. Of course ensure you set the PS3 sound setting to output audio via hdmi instead of optical. See if you prefer the sound this way but as BB said the PS3 fat will decode the HD soundtrack internally. Let us know how you get on. Cheers
__________________
System- Philips 42 PFL7404, Yamaha RXA1010 Aventage AV receiver, Tannoy HTS 101 5.1, Qed Silver Anniversary XT Speaker Cable, Sony PS3 Slim, Sky+ HD, Wireworld Chroma 6 HDMI, Wii. Samsung Galaxy SII. Acer Media PC Laptop
Englishbull
Hi
well changed the optical for HDMI and changed the settings, Stuck a Blu ray on to see how it sounded. In short not good,Sound was not good didn't really seem to be coming from rear speakers and talking was coming from both front speakers rather than centre. No real bass from the sub either.
Any ideas why this is?
Do i need to change something on the PS3, i see when setting HDMI as output there a quite a few options on sound to choose from i.e a lot PCM boxes to tick.
Any suggestions?
thanks
__________________
GSB
GSB's picture
Hi Englishbull,have you thought about adding a blu-ray player?would be a lot simpler,not saying the picture would be much(if any)better but it would be quieter and loading times faster.A decent bdp could be had for less than £100 Smile
__________________
PanasonicTX-P46GT30B..Yamaha RX-A1010...Music Fidelity M3i...OPPO105EU...KEFR100/R200C/3001SE/HTB2SE...SkyHD2TB...QED Copper Speaker Cable /HDMI/Analogue...PS3...IPAD2
duaplex
duaplex's picture
Also the Fat PS3 is not like the Slim where you have HD audio. The AMP will only see it as PCM even in bitstream mode. Get a Bluray player.
__________________
Panasonic 65" 3D TV (P65VT50), Pioneer LX83, CA, Azur 751BD, PS3, Water Cooled Xbox 360 (Modded), Nintendo Wii U, Sky HD+, i7 PC overclocked with 6850 HD Radeon, CM8 Fronts (Bi-Amped), CMC Center (Bi-Wired), DS3 Dipoles, PV1 Sub. Van Den Hul M.C. Snowtrack >Halogen Free< wiring, Chord Active Silver HDMI's, Cabridge Audio AUD700 Analogues Interconnects, QED Signature Subwoofer cables, Chunky Monkey custom oak AV cabinet.
duaplex
duaplex's picture
As Always i just noticed Big boss beat me to it Smile
__________________
Englishbull
Hi  duaplex, thanks for coming back.  This had crossed my mind about getting a seperate Blu ray player.
So my question is Any recomendations? What is one of the Best?
cheers
__________________
duaplex
duaplex's picture
There are a good few players, how much are you looking to spend?
I would recommend the BDT500 as the best budet player.
__________________
Englishbull
Well could probably go up to around £300.
__________________
GSB
GSB's picture
For that you could look at getting a new ps3:)
__________________
GSB
GSB's picture
An older model of bdp will serve you well,be at least half its original price too....got mine in 2011 for £170,saw a boxed second hand one on flea-bay for £60!
__________________
