31 posts / 0 new
Last post
theflyingwasp's picture
Last seen: 10 months 1 week ago
Best 5.1 setup
Hi ,I have decided to go with the yamaha aventage 2020 receiver but as for the speakers  I don't know what set up to choose
1- monitor audio apex 5.1
2-monitor audio RX6 AV12 5.1
3- monitor audio RX8 front  RX centre RX8 rear RXW12  5.1
will I get better surround sound from 2 rear RX8s or should I just stick to the RXFX that come with the RX6 AV12 5.1 package  ,the room I have is 4x4m will the extra rx8s just be too powerful or are they just ment to be front speakers,will the RXFXs do a better job of surround sound.
also I don't have space for the extra rear speakers for 7.1 if I was to buy 2 more monitor audio speakers and place them in the middle of the room between the front and rear speakers would I benifet from the extra channels or is this just a waste of time and money??
would the yamaha aventage 1030 be enough for my needs above??
14 inch Toshiba TV/ Hitachi VCR + Remote,Alba Radio Cassette Player,Sony Walkman,Blue Lava Lamp.3 issues of Empire Movie Magazine.
Leeps's picture
Last seen: 2 weeks 1 day ago
Couple of questions Mr
Couple of questions Mr Wasp
What would you say is the percentage balance between music listening & tv/movie watching?
How far away from the rear wall can the RX6/8's be placed? They are rear ported (& front-ported) and could create problems with bass boom if used too close to the wall.
I think if I was placing a system in a room your size (not too different to mine), I'd be inclined to look at the Apex.
Maybe users of RX6/8's may be able to comment on how their experiences with speaker placement, how they prevented bass boom & what sized rooms they were using the systems in.
Tidal, Cambridge 640CD, Pioneer BDP450 Bluray, Pioneer VSX-2021 AV receiver, Ruark Talisman III, Ruark Dialogue II centre, Ruark Epilogue II rears, MA R370HD sub, Panasonic TX-P42G30B plasma
RE: Couple of questions Mr
Hi there leeps it will only be for movies i only listen to music on sundays when im cleaning and i stopped watching tv about a year ago.the rx6 and 8s will only be about 10inchs from a stone wall.
macdiddy's picture
Last seen: 1 hour 32 min ago
RE: Best 5.1 setup
Hi there.
In reply to your question, I think that you would get a better sound using a pair of RXFX speakers rather than a second pair of RX8's as in the size of room you have, two pairs of floor standers would sound overpowering with bass boom possible unless you can move the speakers further out into the room and away from the corners, The RX8's are a large speaker and need approx 1 to 1.5 foot space from a wall to perform at their best.
I personally use a full set of monitor audio BX series speakers in a room size of approx 6x4m, which include a pair of BX6, a BX centre, two pairs of BXFX's surrounds, two BXW10 subs and a pair of BX1's for extra height channel, using a Onkyo TX-NR818 to drive them and I have no problems getting enough volume to fill my room but more importantly it is good quality sound with no bass boom.
So to recap, I think you should go for either option 2 or 3 as I think either one would work best, option 1 is a small system and I don't think it would work well with the two receivers you mentioned.
In the end its up to you but I thought I would share some of my experience, hope it helps.
macdiddy's picture
Best 5.1 setup
Hi there again.
sorry, I meant to say option 3 but without the extra pair of RX8's and using a pair of RXFX instead.
Thanks for the info.i thought
Thanks for the info.i thought 2 pair of RX8's were a bit much .
Leeps's picture
RE: Best 5.1 setup
I think the above comments illustrate how important demonstrations are because much of this is down to personal taste, but I would re-state that speaker positioning is crucial. Don't under-estimate the affect this can have on the overall sound.
Also, do bear in mind that large speakers and smaller speakers each have their own advantages and disadvantages.  Smaller speakers in a sub/sat system are less affected by the bass as they use the sub for that, which means they are better placed to maintain speed, timing and dynamics.  You may like to check out the Apex user thread on this forum.  There are many happy users that report their experiences.
Incidentally, Yamaha and Monitor Audio are repeatedly praised for being good partners by users on this forum.
mr malarky's picture
Last seen: 2 years 8 months ago
RE: Best 5.1 setup
Hi Wasp,
I'd suggest the RX package rather than the apex if you have the room for the front mains. That's not a criticism of the apex package, just an opinion that if you have the space then full size speakers will do more justice to movies with a lot of music in the soundtrack.
As per other posts, RXFX will more than suffice for rears (floorstanders woukd be overkill). Given that it's mostly for movies I'd suggest the RX6's would be fine (again, the RX8's would probably be overkill).
if you can stretch to the higher-end yahama model then go for it, best to give the speakers the extra 20w per channel if you can.
Let us know what you decide and would be good to read a review once it's all up and working?
Simon Pinkney's picture
Last seen: 4 weeks 4 hours ago
RE: Well I can highly recommend
Well I can highly recommend both the RX8's and also the Apex System. I currently have a 7.1 system using RX8's for the front left and right and Apex for the rest. The soundstage is awesome and I find after the system calibrates the speakers it all blends in beautifully. I considered the RX6's but got a great deal from Eric Wiley in Castleford on the RX8's in piano black. Movies are amazing. Sound effects are thrown around the room brilliantly and with some force when required. Musical elements of films also sound amazing. Crank up the volume and for a home cinema set up I don't think I can ask for much more. Equally at quieter levels these speakers perform great. With music the speakers are brilliant. The RX8's are awesome with stereo and go very loud with great clarity. The review on here says the base sounded a bit flabby or boomy but I don't think that at all. Base levels are very deep and high levels are crisp but to me everything blends in great. I am amazed at how they fill me room with sound it sometimes sounds like all my speakers are on. There not because I check :-). I also use an extended stereo setting which as suggested uses the RX8's and the Apex. Again, I can't fault them. I love these speakers.
I did find the bass a bit boomy initially on the RX8's, probably not helped because they're relatively close to the wall (about 8 inches), and had to use the supplied foam bungs to start with. That cleared up when I bi-amped them though, tightened up the lower end noticeably.
I went for the RX8's though because I use my set-up for music as well as movies; wasp is aiming for 90%+ movie use by the looks of it, so on balance I think he'd be fine with the RX6's and put that cash towards getting the higher spec yamaha to make sure they really do sing.
Forgot to say, thumbs up for extended stereo with music!  Smile
ric71's picture
Last seen: 11 months 1 week ago
RE: Best 5.1 setup
I would suggest the Apex. A great sub/sat system will have far fewer issues with the listening room and provide a more flexable approach to optimising the bass.
I would however recommend that you invest in a good sub and not the Apex AW12 sub as it's not the best value for money.
I ran ran the Apex for a while and found them to be superb and more than capable of partnering some high end amplification and subwoofery.
MK Sound MP300 LCR, S300T's surrounds, MP150 front heights, S150T rear heights, dual X10 subs, Denon 7200wa, Lyngdorf TDAI 2170, Lyngdorf SDA2400 power amps, Oppo103, Sony 65" 9305..............
RE: Best 5.1 setup
Thanks for the information and suggestions guys.what do you think of 2rx8s for the front right and left ,the RX centre and 2 A10s for the rear
i have no need for the extra watts on the 2020 receiver or the zone2/4 function,what am I paying  extra money for  over the 1030 yamaha aventage.
RE: Best 5.1 setup
That would sound good in my opinion but wouldn't it then be better to stick to RX for the surround backs as well? I know your mainly interested in movies so why not choose the RXFX for the back or sides. I think the Apex speakers are nicer looking system especially for the surround speakers. The A40 centre also looks nicer than the RX centre in my opinion. I like how my RX8 in piano gloss black look and they do match the Apex sats very well. Sorry I keep editing my message. I've just looked at your room size. 4x4 in my opinion is quite small for the RX8's. My living room is abount 10m long and the RX8's and Apex swamp that with sound! I'd go for the Apex 5.1 system. That will be more than loud enough I think! In fact I go as far as saying it would sound bloody amazing Smile
RE: Best 5.1 setup
Also, if choosing the Apex then the Yamaha 1030 would be perfectly good enough. I have the Pioneer LX55. I hardly ever have it pumping out sound at levels its actually capable of although I have cranked it up very loud.... mainly when the wife and dog are out and yes it sounds great. Peronally, whilst its always nice to buy bigger more powerful amps, you probably wont need to.
RE: Best 5.1 setup
Hi simon
yes the a40 is a nice looking centre speaker,I think deep down the apex is the best choice for me,I just really really like the look of the RX6 or RX8 in gloss black at either side of the tv .what I want seems like far to much power for the space I have  :wall: I don't want to buy speakers that will end up distorting sound rather than giving me good quality just because I can afford them,I have no doubt the 5.1apex will sound awesome it's one of the biggest threads on here but like I said that high black gloss finish on a couple of floor standing speakers next to my tv was what I was after.
Pages
Log in to post comments
