best 5.1 package for dsp ax763
i need little advice,i have yamaha dsp ax763 running wharfadale 9hcp with q aucustics 1000si subwoofer(insted of wharfadale sw150).
The sound is ok,but not what it used to be when i had epos els303 as a fronts.but even before the sound is not great,soundstage,bass..etc not good.i need some great sounding kit the money can buy i was thinging of keepinng the centre and rears,and get some sub and fronts (preferably floorstanders for music) i have looked at
wharfadale diamods 9.6
wharfadale diamods 10.3 or even 10.1 bookshelf
tannoy revolution dc4
kef iq5se
b&w 685 bookshelf
the budget for fronts is £400....but if theres is better for little bit more that would intergrate into my system best let as know.
as for subwoofer: wharfasale diamond sw250,Tannoy ts10...and any other depends what fronts i will get.any advice would be great from you guys,my room is 8m long and 6m wide ,tv is on the long side with the sofa sitting in the middle of the room on the long side.its pretty big room for the system but i'm sitting about 4m from the system so that should help it or not?
That's a very large room!! Tanny ts10 won't fill it, also they not heavy enough!!
Sold 1 and replaced with sw150, twice as heavy and stays on granite rather than wandering around.
Sub:
Suggestion: BK XXLS400
http://www.bkelec.com/hifi/Sub_Woofers/XXLS400DF.htm
It has great feedback on forums. Powerful with 30cm drive unit. Should fill you big room.
Front:
I would go for kef iq5se
- Login to post comments
Hi
I've got Yamaha DSP-AX763 ang going to buy Wharfedale 9.1 + 9.0 + 9.CS
I think they're very good value for money
