6 posts / 0 new
Last post
admin's picture
Last seen: 3 days 6 hours ago
AV receiver or sound bar
Help wanted.
I am moving house and will be investing in my first LED HD (probably Smart) TV but am unsure what I need to go with it to get the best sound out of it and to hook up to blu ray, laptop, etc.
We are not huge film/addicts and we do not want clutter, so no large number of separates or masses of wires. Appearance is important.
So my inclination is to stay away from Home Cinema systems.  However, we want good quality so the picture, sound and versatility is most important.
Is a high quality TV plus a good quality sound bar the solution?  I would like to add a Blu Ray and be able to run a laptop through the TV for pictures, etc. and maybe one games console, but that is about it.  A Smart TV will provide me with the other applications I need.
Or do I need an AV Receiver (which is what I am being sold)?
If it is just a sound bar, what do you recommend?  If this could be wireless, so much the better.
Andy Clough's picture
Last seen: 5 hours 9 min ago
RE: AV receiver or sound bar
We've just tested six soundbars in the October issue of the magazine, on sale August 24th, with models from Yamaha, Sharp, Samsung, LG and Panasonic. Well worth a read before you buy.
Editor-in-Chief of What Hi-Fi? and whathifi.com
sta99y's picture
Last seen: 10 months 1 day ago
Jat5361 wrote:
Help wanted.
Hi 1st of all it depends on your budget!! You want the bestt picture?, as least clutter as poss?, and hook up BD, games console? If it was me hold back 30% of your tv budget and get your new tv you buy calibrated by an ISF Calibrator, as you could spend a grand on a tv and have a crap picture, but if you spent 700 on tv and 300 gettin it set up properly you would see a huge difference. Sound bar seems to suit your needs if you don't want lots of wires and clutter. Most have a variety of inputs etc... Im sure others will give their advice also. Mine are my opinions only.
Best of luck.
dave_k's picture
Last seen: 8 months 2 weeks ago
You should consider Q Acoustics QTV2 if you want good quality but clutter and fuss free sound. It's a 2.1 system that bolts to the back of your TV and all you see is 2 slim satelite speakers. The sound is excellent - decent bass, good clarity and nice clear treble. Some reviews mention some sibillance issues, but in my room, with soft furnishings etc it's not a problem. I'm very happy with it i have to say.
Anonymous's picture
sound bar or AV? Which gives the best surround sound?
Trefor Patten's picture
Last seen: 1 year 3 months ago
Soundbars (esp Yamaha) can be a very good second best, but that is all.  I have been hugely impressed by the ability of Yamaha products to create the illusion of surround and quality, but that is all it is, an illusion.  If, after auditioning one you are happy with the sound, there is much to be said for the lack of clutter. But, and it is a big but, it will always lack the absolute quality of a full AV system.
Log in to post comments
