5 posts / 0 new
Last post
Dan Fahey's picture
Last seen: 9 months 3 days ago
Any suggestions for hiding cables in a new build
Hi - I am currently building a new house and will have a dedicated room for home cinema - going to have an Epson 6100W, Yamaha RXV775 and it looks like Dali 1 5.1 or Dali 5 5.1.
The house is just being built and I am wondering if there is anything I could suggest to the builder to hide speaker cable and hdmi cable.  (I mention hdmi as I hope to have my AV equipment, PS4 etc... at the back of the room and I might use a tv from time to time instead of the projector for gaming).
Any suggestions greatly appreciated.
bigboss's picture
Last seen: 1 week 1 day ago
Yes, you can put cables in
Yes, you can put cables in during the first fix of the build stage. That's the best time.
Plan where your speakers and projector will be, and where you're keeping your AV receiver etc. Also don't forget you'll need a power supply for the projector.
bigboss's picture
You can install wall plates
You can install wall plates for a neat look:
http://www.supercellaudio.com/HDMI-Wall-Plates.htm
Some shops can custom make according to your requirements.
FunkyMonkey's picture
Last seen: 6 days 7 hours ago
I did just this a couple of
I did just this a couple of weeks ago.
I tacked on my own cables to the breeblock inner walls. Took me a whole day. but then there were 11 speakers to wire up (Dolby atmos ready), subwoofer cable, hdmi to tv, hdmi to projector, cable for motorised projector screen, internet cable to tv, internet cables to router (ready for a switch). I collected them all in back corner of room where I will put a cupboard where all the hardware will sit and hide the plethora of wires coming out of wall.
I didn't want to spend money on superfluous wall plates.
Don't forget to specify enough sockets. You can't have too many sockets.
Forgot to say, after I had
Forgot to say, after I had done it, the builder kindly put metal cable plates over the wire runs for easier detection and protection in future.
He then plasterboarded over then obviously plastered.
Log in to post comments
