Antimode Advice
3 replies [Last post]
Pittodriered
Pittodriered's picture
Folks,
Just set up my anti mode and looking for a bit of advice from other owners. I ran the anti mode calibration then ran through my avr calibration. The avr has now increased the subwoofer distance by approx 1.5m, whilst the Antimode manual suggests 90cm. BK Elec are closed for their hold so I can't contact them. Should I leave the distance as set by the avr or adjust by the recommended amount stated by BK Elec.
Also has anyone played about with the lifting EQ settings? I have just left mine as the calibration set it, which is subsonic filter only.
__________________
Lounge: Pioneer PDP-LX5090 ~ Yamaha Z7 ~ Pioneer BDP-LX52 ~ Pure AV PF30 ~ Sky HD ~ Playstation 3 ~ Monitor Audio R270HD, R225HD, R90HD ~ BK Elec XXLS400 ~ Antimode 8033C ~ Russ Andrews and Clearer Audio Mains Cables ~ Bose Sounddock
Bedroom: Samsung 37ES6300 ~ Samsung BDP-1580 ~ Tacima CS929
ric71
ric71's picture
RE: Antimode Advice
I adjusted my distance as per BK's advice as the Antimode does introduce a slight delay.
I just left the Antimode at standard as it worked a treat. Experiment with the EQ lift and see which you prefer is my advice.
Has the Antimode improved your sub?
I found it made a huge difference to my sub at the time.
__________________
Anthem MRX 300(used as processor),Anthem Statement A5 power amp,MK S150MKII's LCR,MK S150T rears,Paradigm Studio Sub15,Perfect Bass Kit,Sonos ZP90 ,Qnap NAS,Pioneer BDP-LX55,Isol-8 Cleanline2 mains conditioner,SKY+HD,Audioquest Diamondback interconnects. ATV3,iPad4.
Pittodriered
RE: Antimode Advice
Thank for the reply. I haven't had a chance to test it properly yet with a blu ray, hopefully i'll get onto that tonight, so I can't say how much improvement I've gained.
I'll leave the settings as they are and experiment with the bypass tonight.
__________________
ellisdj
ellisdj's picture
RE: Antimode Advice
I would say leave your sub distance alone - I think the BK manual says adjust the distance by approx 90cm.
However its s time delay really rather than an actual distance so what your mic picks up will likely be more accurate than you with a tape measure.  I think thats true of most modern receivers - I have had a Z7 - I would let YPAO decide
__________________
Meridian G61R, HD621, G55, MC200, MS600
Pioneer LX5090 Calibrated, Marantz UD7007, HIFi Racks Podium Reference
Monitor Audio GX100, GXC150, Apex A10, BK XLS400 (set with hard knee house curve)
Graham Slee Spatia (SC) Graham Slee Cusat 50 (IC x 5 Analogue,x 4 Digital)
