Angle of centre speaker.
Afternoon ppl,
My centre speaker sits directly in front as it should, however, it's not really angled towards my ears. It's aim is more towards my lower chest. Any ideas what I could use to change the angle so it's more at ear level???
Cheers Jammoe, much appreciated.
Front - squash ball cut in half
Rear - Blu-tack
Perfect angle for me.
Personally, I use these:
http://www.amazon.co.uk/Auralex-MOPAD-MoPAD/dp/B0002D0B4K/ref=sr_1_1?ie=UTF8&qid=1345989837&sr=8-1
This would also be my suggestion.
It supports, isolates and angles, all at the same time......it's the hifi equivalent of a brassiere!
Nothing finishes the look of a system quite like a door stop wedged under the centre speaker, lol.
Yup I use the same. Depending on your centre, it can complement quite well - my black B&W centre sits flush on top and blends in nicely with the pads.
Out of interest, which model do you have??
Goodness.... that's something I never as in NEVER thought about... great question with equally great answers... looking into it.
Sad as it may seem I have mine sitting in my cabinet and it is level.
I use Flatfeet Sorbothane pads under my centre speaker. See link before for details. I use the larger ones at the front and the smaller ones at the rear, which angles my speaker perfectly.
This would also be my suggestion. It supports, isolates and angles, all at the same time......it's the hifi equivalent of a brassiere!
Just ordered the same for my Centre speaker
Will give some feed back once installed
Will it? Why would you want that?
I found a bouncy ball when cleaning out my sofa. Amazing what you find down there. Cut it in half and used that.
- Login to post comments
Main System - Denon DBP-2012UD / Sky HD / Popcorn Hour / Squeezebox Touch - Panasonic 65VT50 - Pioneer VSX-LX53 - B&W 685/686/HTM62/ASW610
