Amp to partner my old KEF 5.1 satelites and sub
3 replies [Last post]
Will Harris
Will Harris's picture
Thanks to my Dali Ikon 6 5.1 speaker upgrade, arriving this weekend, I have a set of Kef 2005.1 eggs and sub to re-home. I'm thinking about putting them in the bedroom and mounting them just below ceiling level, pointing down in a 5.1 channel set up for use in primarily a matrix 5 channel stereo mode.
My old Pioneer DV565D will feed into a receiver and I don't really want to spend too much money. For £180 I can buy a Denon AVR-1507. Is this the best value for a multichannel amp to power these speakers. It'll be mostly playing my iPod, connected in a rather basic fashion and occasionally a DVD or CD and perhaps a bit of good old fashjoned radio in the morning.
My QED Silver Anniversary cable is going to be feeding the new Dali's so what should I buy for the KEFs at minimum expense in keeping with the whole budget nature of the kit. Looking at about a 30m total length of cable. Room is only 7x13ft.
Cheers!
__________________
JVC DLA-HD1 -- OPPO BDP83 -- ARCAM AVR600 -- DALI Helicon 800 Mk1 -- BK Monoliths FF and DF
Andrew Everard
Andrew Everard's picture
Online
Re: Amp to partner my old KEF 5.1 satelites and sub
 Yes the Denon will be fine, or something like the old Yamaha RX-V361 or Sony STR-DE400, which you can find for even less, if you don't mind a spot of springclippery on the speaker terminal front (and why should you, at this level).
And speaker cable? While you're at Richer Sounds looking at the Sony or Yamaha (oops, bit of giveaway!) you could do worse than the in-house Gale Symphony 200, at 99p per metre.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
Will Harris
You know, you should charge for this advice! Oops, don't worry I'll be buying the September edition! Mate, you're a legend. Thanks.
__________________
Andrew Everard
Online
 Per-chingg!
__________________
