Advice on speaker cables
7 replies [Last post]
dukeden
dukeden's picture
I'm looking for speaker cable for my av project. So far I have a Yamaha RX-A1020 receiver, and I'm currently looking at speaker options. Maybe B&W 684's, CM8's, Monitor Audio RX6's or RX8's, I'm hoping to demo in the coming week. I'll be buying the front left and right first, then adding to the system as and when I can afford to.
My question to you guys is what speaker cables to go for, I'll need 2/ 2m lengths for the left and right. I've looked on WHF best buys and seen the Audioquest FLX-SLiP 14/4 at £5.80 a metre, plus my local hifi shop sells these. Would these cables be adequate? or would buying the cable be like putting firestone tyres on a Aston Martin? I'd appreciate your advice and experience of matching cables to similar receivers/speakers.
__________________
Sony KDL-32EX703, RX-A2020, RX6, A40 Centre, Sony BDP-S790, Sky+HD, QED Silver Anniversary XT, Audioquest Pearl HDMI, Braun Oral B Wink
abacus
abacus's picture
RE: Advice on speaker cables
All you need is some good quality multi strand cables which can be picked up from places like Maplins, as more expensive cables make absolutely NO difference to the sound, (As has been proven in test after test after test) so don’t waste your money on them.
Bill
David@FrankHarvey
David@FrankHarvey's picture
Dukeden
Opinion is divided regarding the difference cables make. The best thing to do is to ask your dealer if he has a couple of cable you can borrow to take home and try in your system. You need to listen for yourself in your own system to decide what differences a cable will make, otherwise you're just at the mercy of people who tell you that you will or you won't hear a difference.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
FennerMachine
FennerMachine's picture
For my front speakers I use cheap £1.00 per metre multi strand cable.
I have more expensive cable for my centre and rears but only because I have them from when I used to spend lots on cables. I had to change my front cables due to a change of amp.
I have thought of getting thinker cable such as 4mm, around £4.00 per metre, but can't be bothered.
My system sounds good enough as it is. Good cables will make a difference over super-cheapo-bell-wire-cable and some systems may respond to fancy cables.
Try some cheapo cable from a local store and listen for a while. Then take some high end cables for a home demo – probably most noticeable on front pair + centre.
If you notice a worthwhile difference get the better cable (after trying a few maybe).
If you notice no difference then stick with el cheapo.
From experience, I've owned cables costing hundreds for 2×2.5 metre runs.
I prefer (notice no difference) my el cheapo cables.
__________________
CA 751BD , QUAD 44 pre amp, Quad 303, Quad 21L2
Denon AVR-3801, Samsung LE32R87BD 32" TV, Quad L2 Centre, 78DS
dukeden
dukeden's picture
Okay peeps, I'll take your helpfull advice on board. I'll certainly drop by my local hifi shop and see if I can borrow some cables. Makes sense if they'll let me try them out first. I don't really want to spend a small fortune on cables if it's not required. On the other hand I don't want my system to lack due to me saving a few pennies
__________________
seemorebtts
seemorebtts's picture
speaker wire changes the sound from your amp to the speakers.they do make a difference.you just need to find out which ones you like.
__________________
duaplex
duaplex's picture
Provided you have a good shielded cable you will be ok, for your system spend no more than £10 a meter IMHO. I have the CM8 package and use the van den hul wire, it's silver and shielded, so it ticks the boxes for me.  As to whether a more expensive cable, say £20, sounds audibly better I really could not say from experience.
With analogue cables quality is everything and those tiny strands do matter.
They say spend 20% of your budget on cables, good rule of thumb.
Now who wants to start the debate about 'burn in'  excellent!
__________________
Panasonic 65" 3D TV (P65VT50), Pioneer LX83, CA, Azur 751BD, PS3, Water Cooled Xbox 360 (Modded), Nintendo Wii U, Sky HD+, i7 PC overclocked with 6850 HD Radeon, CM8 Fronts (Bi-Amped), CMC Center (Bi-Wired), DS3 Dipoles, PV1 Sub. Van Den Hul M.C. Snowtrack >Halogen Free< wiring, Chord Active Silver HDMI's, Cabridge Audio AUD700 Analogues Interconnects, QED Signature Subwoofer cables, Chunky Monkey custom oak AV cabinet.
dukeden
dukeden's picture
Thanks for that. I have a friend that's very kindly offered to lend/give me 5/6m of some QED cable. I'll try it out and if it's half decent I'll just buy him a couple of cold ones  Beer and save some pennies.
__________________
