Yamaha speakers + amp
6 replies [Last post]
Specter
Specter's picture
Hello everyone!
I'm new in the HI-FI world and would appreciate your help very much. I'm intending to buy Yamaha N-S777 speakers (after listening to them) and still deciding which amplifier to buy along. I'm considering among these:
- Yamaha A-S500
- Marantz PM-7004
Now, which one to choose? I know that I shoud listen to both and then decide, but I don't have that option. I'm listening rock music mostly and basses are very important to me. Is it true, that Marantz doesn't have those deep low basses? Would my untrained ear notice the difference between those two amps as it comes to basses?
Thank you very much for your help..
Best regards
ear
ear's picture
RE: Yamaha speakers + amp
NS-777 series have very thin and  fizzy treble.(I have ns-333) ns-f150 are better sounding speakers for rock pop etc and cheaper also than ns-777
__________________
Yamaha AX-397 + Yamaha NS-333;
HK 3390 + Tangent Millennium 200;
Cambridge Audio Sr10 +Cambridge audio  S30
ear
ear's picture
but the ns-777 go well with the yamaha amps because the amp boosts a bit the mids compensating the thin treble.just dont expect bass to be that great with yamaha amp
__________________
Specter
Specter's picture
...well, I decided for 777 after hearing them with different tipes of music and it sounded very well to me. So you think, that I should buy Marantz along? Would it provide better basses?
ear
ear's picture
me thinks yes marantz 7000 series better bass or maybe nad 355
__________________
Specter
Specter's picture
I've decided to go with Yamaha A-S500 and Marantz CD6400. They suppose to go very well together. And now I'd like to know which connection cables to use bettwen those two. I don't wan't to connect them with some cheap stuff. What do you suggest?
Thanks,
regards
ear
ear's picture
I pay no attention to interconnects.any will do.I care a bit more about speaker cable but only between bare copper or silver plated copper.
__________________
