Worth the switch to Naim?
27 replies [Last post]
empacher
empacher's picture
Curious if anyone has compared the Rega Brio-R with the lower end Naim amps or single boxes.
Pretty happy with my set up so don't know why I have the bug but anyway.....   I am wondering if I would be gaining anything other than convenience by going for the UnitiLite?  In terms of amp, would the Nait XS be a step up over the UnitiLite or Brio-R?
Just looking for some opinions before I try and actively coordinate some demos.
thanks
__________________
Rega Brio-R, Rega DAC, Totem Model-1 Signature
BigH
BigH's picture
RE: Worth the switch to Naim?
The only way is to go and hear them. If there is nothing wrong with your sound why bother, just enjoy the music. Generally I would say Naim are underpowered and I would be looking for more powerful amp to upgrade to. I may go and hear them next week, if I do I will let you know.
CnoEvil
CnoEvil's picture
I would agree that it has to be a personal decision.
FWIW. WHF thought the Arcam A19 was a step up, so if you like the Rega type sound, it maybe worth a listen.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
David@FrankHarvey
David@FrankHarvey's picture
To answer that question, yes, the XS would be a step up, but as mentioned, you really need to hear it to see if you like the sound of it, particularly with your speakers.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
stevebrock
stevebrock's picture
thanks
I had the same dilema, went to listen to a unitilite but i prefered the sound of my Rega system and I would of lost money swapping over to naim and i would of had to buy a phono stage too.
Stick with the Rega and enjoy it!
__________________
Synology DS212j > Rega DAC > Rega Brio R > Rega RS1
Rega RP6 / Exact
Chord Chameleon Plus / Odyssey 2
Panasonic TX-P50 GT50 > BDP110e > Yamaha RX-V 667 > Rega Vox
empacher
empacher's picture
Do you mean because many of their amps are in the 30-70 watt range or that they don't deliver the claimed output?  I thought Naims were conservatively rated?
__________________
empacher
empacher's picture
thanks Steve.  Difficult to find those who have listened to both.
Irrational I know, because I like what I have, but I've heard Totem and Naim were a great combo and I've always dreamed of a Naim system for some reason.
I'll probably stick with what I have (and be perfectly happy -and more so after adding an Apollo-R) but might try and demo the Nait XS at some point.  Maybe new Rega amp will be out in a few months to make things even more complicated.
__________________
plastic penguin
plastic penguin's picture
thanks
Concur with the others about comparing different amps and decide for yourself. However, I really do think those Totems deserve a higher quality amp, given they are over £2k. I would be looking at Naim XS as a minimum. I heard the XS last powering Dynaudio Contour S1.4 and it sounded awsome... up to a point.
Can't comment directly on the Rega Brio-R, but as the amp is sub-£500 in the UK, logic tells me that a better quality amp is preferable.
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
BigH
BigH's picture
The rating given the price. Ive been told they lack headroom, so (clipping) distortion can be a problem. I have not heard those speakers but my dealer seems to stock them so maybe give them a go if time. From what I have read they need some careful matching.
pete321
pete321's picture
I recently demoed the Rega Brio-R, Cyrus 6, Audiolab 8200a and Naim Nait XS. All connected to Monitor Audio RX6 speakers and a Rega DAC.
I found the Brio-R a real disappointment, not particularly exciting or articulate to my ears. Cyrus 6 was OK, although not an all rounder. The Audiolab was the surprise of the bunch bearing in mind you can pick it up for between £630-£650. I was mainly auditoning with rock music to give the amps and speakers a real work out. I preferred the Nait XS over the Audiolab, it had more control, however it's more than twice the price. For less money than a new XS, you could get an Audiolab 8200a + 8200p pairing which would possibly equal or exceed the XS for control? I should point out, given the WHF review, I didn't find the Audiolab treble at all bright, I actually found it quite smooth sounding. The Rega DAC would have played a part in that working it's magic.
You need to listen with your speakers, all the above amps sounded very different with B&W 684's connected, albeit the final result was the same for me.
I was captivated by the XS sound and picked one up secondhand.
__________________
Naim Nait XS | Monitor Audio RX6 | J River MC18 | Teac UD-501 DAC | Oppo BDP-105 | Pioneer PDP-LX5090 | Yamaha YSP-4100 | BK XLS300/PR Sub | Chord Odyssey 2
pete321
pete321's picture
My listening room is 5m x 5m and I've never needed to go much past 11 o'clock on my XS volume, and that sounds very loud! Most of my listening is between 8 & 10 o'clock position on the volume control.
__________________
tyranniux42
tyranniux42's picture
Have a listen. I knew the moment I heard it that I loved the xs, compared to the arcam a38 it was leagues ahead with my old 683's IMHO. With my ovators it is a barnstormer. As for output, as long as the the speakers are of a sensible sensitivity then I can't disagree enough, it's plenty powerful enough. Big thumbs up here. I also have the unitilite which has a cracking amp in it, arguably the best part of the machine.
regards
__________________
Main System: Naim CD5XS or DAC Magic -> Naim Nait XS -> Naim Ovator S-400
2nd System:  Naim Unitilite -> B&W 602s3
Headphones: Naim CD5XS or DAC Magic -> Graham Slee Solo -> HD650
Home Cinema: Sony KDL 40D3500, Sony BDP s370, Sony DAV-IS50, XBOX 360, PS3 & PC all into DACMagic for passthru or decoding
stevebrock
I think the comparison between the Rega Brio R, DAC, Apollo R and the Unitilite is very valid - both lovely systems, of course the XS is better amplification but were are talking about £1600 systems here..... One is seperates the other all in one and both have lovely presentations!
__________________
Rega RP6 / Exact
drummerman
drummerman's picture
The XS is a lovely amplifier.
Is it to expensive? You have to decide that. Materially, a no-frills integrated of comparetively low power shouldn't cost that much imo but its a Naim. - Have I heard anything that sounds like it cheaper ... ? Not yet but I'd probably would check out some of Harman's products too.
I could happily live with one but would try and get one s/h and use sensitive speakers with a reasonably benign load though the amplifier has adequate current to be at least a little bit flexible in that respect.
regards
__________________
Pretty ... and pretty proud of it
stevebrock
regards
i bet it is, if I had more money I would be aspiring to one!
__________________
Rega RP6 / Exact
busb
busb's picture
Totems respond well to very good amplification - I'd recommend giving Primare's I22 a listen (£1250). I can also suggest their I32 for £2200 which I heard up against the XS - much better imaging, IMO, as good as the Naim was.
__________________
"The optimist proclaims that we live in the best of all possible worlds - the pessimist fears this is true."
James Branch Cabell
_________________________________________________________
MAINApple TV2 & iTunes Match, CA Azur 751BD or Panasonic P42V20B into audiolab M-DAC, feeding a Primare A34.2 via XLRs, 2x 5m of Atlas Ascent 2 firing up Totem Arros.
ON THE HOOF: iPhone 4GS/Sennheiser MM450.
Another interest:
http://www.flickr.com/photos/busb/
