8 posts / 0 new
Last post
admin's picture
Last seen: 1 day 19 hours ago
worth saving ?
Got a Pioneer DV-717 dvd/cd player for free today is it worth using it as a cd separate if i hooked it up to a amp ? or should i dump it ?
Got it new in a box unsold !Big Smile
8009514's picture
Last seen: 6 months 3 weeks ago
Re: worth saving ?
You can dump it in my direction if you like!
Marantz CR603, Wharfedale 121s, Maplin OFC speaker cable.
Pana TX - L39EM6B, Pana DMR - EX769, V+, That Cable HDMIs, Orbitsound sound stage.
Anonymous's picture
Re: worth saving ?
that good then compared to today ? i know it was expensave when new.
Seems ill keep it soCool the retail store i work for had 3 i saved this one from recycle.
idc
idc's picture
Last seen: 1 year 11 months ago
Re: worth saving ?
What digital/optical outputs does it have? You could consider using it as a CD transport and connect it to a DAC and the DAC to the amp. You are likely to get better CD sound that way than purely using it as a CD player connected straight to an amp.
Anonymous's picture
Re: worth saving ?
It has digital coax and fibre optic connections which should i use ?
optical is ment to be better right ?Hmm
John Duncan's picture
Last seen: 5 days 15 hours ago
Re: worth saving ?
What happened to the other two? Indifferent
Moderator: john.duncan.whf at gmail dot com
System burgeoning
Re: worth saving ?
(coax is better though)
System burgeoning
Anonymous's picture
Re: worth saving ?
ok thanks  .
coax it is.
Log in to post comments
