UPDATED: Cambridge Audio unleashes its Minx micro speaker system
Dinky sub/sat speaker systems cost from £350, available in 2.1 or 5.1 versions with a choice of three subwoofers
What we saw and heard – even though they were pre-production samples – certainly piqued our interest.
Cambridge Audio has created three 21cm square, forward firing subwoofers of differing power – 200W, 300W and 500W – to match the dinky Minx satellite speakers. All the subs have gain, phase and crossover controls, and use one-piece aerospace grade aluminium cones.
You can build a simple 2.1 system, or go for a full 5.1 rig, depending on your requirements. Each standard Min10 satellite speaker measures just 8cm square, and there's a bigger version, the Min20, which is effectively two of the standard drivers combined into a single unit.
All the systems all use high-end BMR (Balanced Mode Radiator) technology.
BMR drivers combine the 'bending wave' principles seen in advanced flat panel speakers, but also feature pistonic movement (backwards and forwards) just like a traditional speaker.
"This bestows Minx with a much wider frequency response than comparable style speakers, meaning they can deliver a significantly better bass response," claims Cambridge Audio.
Designed to work equally well with music or movies, the Minx systems are finished in gloss white or scratch-resistant black, and are made from acoustically damped thermo polymer and extruded aluminium.
The latest hi-fi, home cinema and tech news, reviews, buying advice and deals, direct to your inbox.
A simple wall bracket is included as standard, while table top stands, swivel wall brackets and floor stands are optional.
The Minx range will be available from November. Prices start from £350 for a basic 2.1 system, to around £500-£600 for a mid-price 5.1 set-up and £1200 for the top-of-the-range model.
What Hi-Fi?, founded in 1976, is the world's leading independent guide to buying and owning hi-fi and home entertainment products. Our comprehensive tests help you buy the very best for your money, with our advice sections giving you step-by-step information on how to get even more from your music and movies. Everything is tested by our dedicated team of in-house reviewers in our custom-built test rooms in London, Reading and Bath. Our coveted five-star rating and Awards are recognised all over the world as the ultimate seal of approval, so you can buy with absolute confidence.
