64 posts / 0 new
Last post
Sunny98007's picture
Last seen: 3 years 7 months ago
What's your opinion about B&W802D?
I intend to be an owner of 802D? Would you like to say something?
DocG's picture
Last seen: 9 hours 55 min ago
RE: What's your opinion about B&W802D?
Good for you!
(but posting your question in 3 different threads makes things more complicated than necessay...)
Bluesound Node2 -- DEQX HDP-3 -- 4 x Hypex NC-400 -- modded Magnepan MMGs
CnoEvil's picture
Last seen: 6 days 4 hours ago
What is your ancillary equipment?
What other speakers have you compared them with?
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
arashid's picture
Last seen: 1 year 9 months ago
if you need to ask, then maybe it's not for you ?
just joking. of course these are fantastic speakers.
you need to make sure your source is up to it, and the amp is powerful enough.
buy with utmost confidence, it doesn't get any better than this.
Thank you all for your suggestions and comments! I have no other special equipments! Just a set of HIVI  M 200MK3 for my computer. And I  have compared 802D with many other speakers-Tannoy, JBL, Burmester, Sonus Faber, HIVI.  I love classic and symphony. Thus I'm looking for a system best for them. It's said B&W has the best performance for symphony. And I feel comfortable with its sounding.How do you say?
MUSICRAFT's picture
Last seen: 3 days 1 hour ago
Hi sunny98007
What source component/s and amplification have you heard the 802D's with please?
Your budget for source component/s and amplification?
Btw, if its not too late then ATC's active SCM100ALST and active SCM150ALST monitors are also worth consideration. Fwiw. i find the ATC's perform superbly with all genre of music.
All the best
Rick @ Musicraft
Musicraft (Derby) - Specialist Hi-Fi/AV Dealer
My system - Naim Core > Hegel HD30 > Hegel P30 > JL Audio CR-1 > ATC SCM100ASL Professional Monitors > 2 x JL Audio E-112
CnoEvil's picture
If you haven't tried Kef 207/2s, it may be worth the effort.
What is your budget for the amp (there has been some great suggestions on your other thread)?
Thank you for your suggestions! I have heard 802D only with Pass Amp. It sounds not bad! And I am looking forward to hearing 802D with Mclntosh this weekend. Do you think it is right for 802D? My budget for the Amp is about $8k. Actually I have no experience. What I know is mostly from posts. So I need more help. By the way, my whole budget for the system is approximately $20k. Most importantly,what I need is a system that preforms well comprehensively and I was told B&Ws can do. Do you think so? My source is Oppo 105!
ellisdj's picture
Last seen: 2 days 7 hours ago
I hope you have a large listening room for the 802 = you will need to give them some space, especially in the bass.
I guess the dealer will fit it all up for you.
you have a lot of options @8k for amplification - WHF liked Krell with the 802's if I can remember from their review.
mcintosh audio research bryston moon ps audio lots of top brands.
Moon images really well from the various amps I have heard of theirs, I like moon a lot
i don't know if you have considered your room acoustics but to get the most from that kit then its something to bear in mind
maybe £6k amp £2k on room acoustic treatments
System Thread needs to be done
CnoEvil's picture
McIntosh is often recomended as a good match....let us know what you think.
IMO. You should look to a better souce, for a system of that quality.
Macspur's picture
Last seen: 6 days 11 hours ago
With that kind of budget, if you can, you should demo an Accuphase amp and you might want to look at your source too.
Mac
Electrocompaniet EMC1UP, Audiolab M-DAC+, Sonos Connect, Accuphase E470, Harbeth SHL5 Plus, Auditorium 23 SC, HiFi Racks Podium Reference rack, matching LS stands.
Electro's picture
Last seen: 5 days 7 hours ago
How about  pair of Electrocompaniet NEMO Monoblocks , they were originally designed to drive the B&W Nautilus 801's  ( hence the name )  and can be used with one one the Electro pre- amps or some people say that a top class  valve pre -amp works very well with the Nemo's .
Here are a couple of reviews .
http://dagogo.com/synergy-between-electrocompaniet-nemo-monoblock-amplifiers-and-bowers-wilkins-nautilus-800d-speakers
and
http://www.stereophile.com/solidpoweramps/300electro
and the Electrocompaniet  website
http://www.electrocompaniet.no/products/classic/poweramp/nemo.html
 Electrocompaniet EMC 1 UP ,  Cambridge Audio id 100 i pad dock, ipad with Spotify premuim, Monarchy Audio DIP, Electrocompaniet ECD 1 dac , EC4.8 preamp , 2x AW180 monoblock power amps , PMC PB1i speakers . Thousands of Cd's .
Electro's picture
Just though I would add that if the Nemo ( AW600 ) amps are a little over budget the the AW 400 monoblocks are equally as good but with a little less power  ( not that you would notice ) and cheaper .
http://www.stereophile.com/content/electrocompaniet-aw400-monoblock-power-amplifier
CnoEvil's picture
Pathos are also worth considering for the amp.
DocG's picture
Yeah, a Cinema X in stereo mode would do the job!
davidf's picture
At £11,500, I'd say make sure you try a few alternatives!
the little audio company, birmingham
audioquest / audio technica / amphion / bluesound / chord co / cornered audio / elipson / golden ear / innuos / jbl / kef / moon / ophidian / primare / revel / svs
Pages
Log in to post comments
