9 posts / 0 new
Last post
Binman's picture
Last seen: 4 days 20 hours ago
What's my weakest link. Comments appreciated
I recently upgraded my speakers which has got me thinking about the rest of my system. Of the components below, what's the weakest link?
Squeezebox Classic using FLAC
Rotel RA02 used as pre amp
Rotel RB06 power amp
Q Acoustics Concept 20 speakers
Mainly listen to electronic music and a bit of hip hop.
matthewpiano's picture
Last seen: 3 hours 29 min ago
RE: What's my weakest link. Comments appreciated
Nothing is glaring there IMO.  Are you pulled into the music by the system?  If you are, then stick with it.  Don't feel you HAVE to change anything else just because you have upgraded the speakers.
Rega RP3/Elys2/TT PSU- Denon DCD720ae - Denon PMA720ae - Dynaudio DM2/6 - Atlas Equator 2.0 - Beyer DT-770PRO - Mission stands
respe's picture
Last seen: 1 year 1 week ago
If you are using the dac in the classic, thats your weak point. I use a classic in my office system, and the cheap fiio dacs improved it quite a bit, it takes the classic up to the same sort of level as the touch. Tiny box, the digigal cable from Sb to it takes up more space than the dac.
steve_1979's picture
Last seen: 6 days 4 hours ago
No real weak links there IMO. But electronic and hip hop music tend to be bass driven genres with lots of deep bass so it may be worth considering some bigger speakers which would give you deeper bass than the Q Acoustics can.
Binman's picture
Thanks for the replies. I've only just got the speakers so don't want to change them. I did have much larger speakers (bowers 602s3) which gave me great bass, but I'm no longer a bass head!
I prefer the clarity and separation the new speakers bring.
The sound I have is good, but the new speakers have left me wanting more clarity.
CnoEvil's picture
Last seen: 5 days 1 hour ago
I agree with Respe......try a better DAC.
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
Binman's picture
I guess I'll have to start reading up on DACs as I know what they are, but that's about it.
Binman's picture
Which Fiio DAC are you using?
In that case I'd agree with the other suggestions of trying a separate DAC as I've read that the old Squeezebox one isn't quite up to the same standard as the new one which is virtually transparent.
Either that or maybe try some different (more powerful) amplifiers to see how they sound with your speakers. Not that there's anything wrong with the one that you're already using.
Log in to post comments
