What Turntable?
41 replies [Last post]
jakesaunders27
jakesaunders27's picture
Hi All
Wanted to ask what turntable you would recomend for my Rotel 02 Series system. i want to listen to stuff like pink floyd and radiohead in vinyl. what would you recomend i have a budget of around £400-500.
Jake
__________________
Rotel RA-02 - Rotel RCD-02 - Rega RP1 (Soon) - Quad 77-11L's - Chord Cables
jakesaunders27
RE: What Turntable?
anyone??
__________________
Alears
Alears's picture
RE: What Turntable?
You just might get a slightly quicker response if you posted this in the 'Turntables' section ....... still 50 minutes isn't bad for a response time.
Do you intend to get a new one for the budget or are you prepared to go second hand?
__________________
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 Dac/Tom Evans Microgroove plus/Tom Evans Vibe Preamp/Tom Evans modified Pioneer A300R Precision power amp/EB Acoustics EB2/ Chord cables
jakesaunders27
RE: What Turntable?
hi thanks for the reply,
preferably new but suppose i wouldnt mind second hand Smile
cheers
jake
__________________
Alears
Alears's picture
RE: What Turntable?
Probably one of the Rega turntables would be the best for you. New RP3's going for £475 but you would have to find extra for a cartridge. There is a second hand 'Rega RP3 Inspire Quest turntabele' going on Ebay for £435 which is recommended, or failing that look out for a used Rega P3-24 fitted with some sort of cartridge for around £300 second hand (ie see Ebay).
__________________
jakesaunders27
RE: What Turntable?
Sorry I know this is a stupid question but which bit is the cartridge is it the needle bit?
Cheers again mate
__________________
Alears
Alears's picture
RE: What Turntable?
There is no such thing as stupid questions, only stupid answers! Yes the cartridge is the device attached to the tonearm to which the stylus (needle) is attached. Most modern turntables do not come with one fitted (although some do)the choice of cartridge is generally left up to you.
__________________
jakesaunders27
RE: What Turntable?
OK thanks!!
I have just seen the Rega RP1 it has 5 stars from what hifi is this any good? Just thinking about money for a cartridge?
__________________
jakesaunders27
RE: What Turntable?
OK thanks!!
I have just seen the Rega RP1 it has 5 stars from what hifi is this any good? Just thinking about money for a cartridge? As the rp3 uses up most of my budget
__________________
Alears
Alears's picture
RE: What Turntable?
The Rega RP1 is their most basic turntable. It should suffice and, as you say comes fitted with Ortofon cartridge, so it is ready to go. If you are unsure about fitting a cartridge to an arm or just want to keep things simple then it is a good way to go.
Spend a couple of hundred more thougfh and significant improvements can be made on the sound quality front.
__________________
jakesaunders27
RE: What Turntable?
Hi again
Decided on the Rega RP1 will go and listen to it when I have the cash and time but been reading and people are on about a phono stage? What's this and will I need one?
Jake
__________________
chebby
chebby's picture
Online
RE: What Turntable?
jakesaunders27 wrote:
... people are on about a phono stage? What's this and will I need one?
No.
Your Rotel has one built in already. It is labelled as 'Phono' on the input selector knob and the inputs (on the back) are the ones also labelled 'phono'. The first set of inputs on the left (looking towards the back of the amp) next to a knurled screw labelled 'GND'. (The earth connection for turntables that have an earth lead.)
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 4 32GB • iMac • Panasonic TX-L32D25B • Sony BDP-S390 • Vita Audio R1 MkII • Humax HDR-Fox T2
Alears
Alears's picture
RE: What Turntable?
+1 for chebby's 'No' and his his excellent description as to why.
You will not need one for the cartridge fitted to the RP1 or the vast majority of 'moving magnet' cartridges for that matter (should you decide to upgrade it in the future that is).
__________________
jakesaunders27
RE: What Turntable?
hi guys thanks for your replys
seen the rega rp1 performance pack on what hifi but cant find it in any shops online does the performance pack make a big different to the sound quality?
cheers
jake
__________________
Lost Angeles
Lost Angeles's picture
RE: What Turntable?
Lintone Audio have a brand new REGA P3-24 on E-bay for £299.95 + cartridge with free postage.
Is this not a better deal than an RP1.?
Sorry about the bold type.
__________________
Orbe SE/ OL Illustrious 3/ Cadenza Red/Dino + PSU/ Caspian amps
You can't exchange a six inch band for all the poisoned streams in Cumberland.
Alears
Alears's picture
RE: What Turntable?
Hi Lost Angeles. Indeed it is, good spot! good job
Ah. Indeed it would be if it came with a cartridge fitted.... it does not appear to have one.
Believe the OP is a bit doubtful about fitting one himself, hence his plumping for the RP1
__________________
