What next?
26 replies [Last post]
swoosta
swoosta's picture
Heres my system,
Project Debut 3 Turntable with Ortofon OMB5
Cambridge Audio Azur 540a Amp
Cambridge Audio Azur 540c Cd
TDL Nucleus KV1 speakers bi wired on stands.
Any advice on improving my budget system is welcome I listen to Rock/Indie mainly.
It's not a bad budget system but I don't know how to / what to upgrade
__________________
Project Debut 2 with Ortofon OMB5 .Cambridge Audio Azur 540a. Cambridge Audio Azur 540c .TDL Nucleus KV1 bi wired. Speaker cable is Gale Electronics xl160. Audio connects are QED QUNEX 2. Blok 400 rack
chris lowe
chris lowe's picture
Re: What next?
 Swoosta, what cables are you using?
swoosta
swoosta's picture
Re: What next?
Hi, Speaker cable is Gale Electronics xl160
The Audio connects are QED QUNEX 2
__________________
swoosta
swoosta's picture
Re: What next?
How much difference would it make upgrading the speaker cable?
__________________
swoosta
swoosta's picture
Re: What next?
What speaker cable do you recommend?
__________________
stormheader
stormheader's picture
Re: What next?
look in to QED X-Tube XT300 in around the 10 pounds per mt
JoelSim
JoelSim's picture
Re: What next?
Get a power amp, and biamp it with QED Silver Anniversary XT. It will make a significant difference to melody, separation of instruments, clarity, detail etc etc
__________________
Unison Research CDE, Leema Tucana 2, Kudos C2 and some cables.
gregory
gregory's picture
Re: What next?
hello swoosta,have you thought about upgrading the stylus on your project 3,a good choice is the om10 or 20,
it will slot nicely on your existing cartridge and will give you an a/b comparison with your cd.you may find no need to change any of your cables i suppose it depends on which source you listen to more often.the cables you use at the moment are decent enough given your system i use gale speaker cable and qed interconncts
and am very happy with the sound they produce.new speaker cables and interconnects can be quite pricey on the upgrade path but a new stylus for your tt would not be.by all means consider different cables but have a demo,sometimes what you here is different not necessarily better.
Thaiman
Thaiman's picture
Re: What next?
user="sex" wrote:
gale £2 per metre to ixos £10 per metre
Hi my Italiano friend.....when it come to speakers cable, the more expensive doesn't mean better! but yes, i agree that gale is a bit weedy in sound.
__________________
TW Raven AC - Soundsmith SG-410 - MSB 202 - Gershman Acoustics Black Swan - Audioquest K9
swoosta
swoosta's picture
Re: What next?
I'm not sure how to biamp can you give some details
__________________
Thaiman
Thaiman's picture
Re: What next?
I always buy 1 good amp or pre/power rather than bi-amp.
__________________
swoosta
swoosta's picture
Re: What next?
This is all foreign to me, can someone give me some heads-up about using anything else other than an amp connected to the speakers, I don't know about bi amping pre amps?
__________________
silly
silly's picture
Re: What next?
Stop worrying,get some better speakers, forget all this speaker cables and interconnect malarky.
silly
silly's picture
Re: What next?
Nothing,zero,zilch,cables make minute differences,and yes I have expensive ones,change your speakers,the Cambridge kit can take a much better pair of quality standmounters.
silly
silly's picture
Re: What next?
user="sex" wrote:
silly dont be silly
About what?
gregory
gregory's picture
Re: What next?
hello again swoosta,i hope by now you are not getting confused by the upgrade path,1st cables and ic's then a new stylus then biamping then speakers,bloody hell it's enough to make you think sod it i'll buy a little all in one and be done with it,but don't give up, some advice is better than other's but only you can decide.have to agree with silly though.your cambridge kit can take better speakers,the tdl's are ok but there is much better for not much money,by the way how did you get on with your tt.the om5 should track at 1.5 grams,to do this level the arm so it floats about 1mm above the platter turn dial to zero set tracking force to 1.5 or 1.75,a bit more will track better in the groove of the record set anti skate to tracking force,on the project the line sits in the notched groove put it on 2 listen if sounds ok leave if not put on 1,you may have to experiment with this.i think the best advice i can give is make sure your kit is set up right,good stand connections right way round and listen to any changes over the next couple of months,your kit may not have run in yet and you may be pleased by the sound it produces and it's free.good luck.
