What is the weakest link?
35 replies [Last post]
eliotn
eliotn's picture
Hi all,
My current system:
KEF Q300
Marantz PM6004
CA DacMagic -> playing FLACs, AIFF, etc...
Cables: Chord Carnivals bi-wire
Room: 4x4m
Music: Jazz, Electro Jazz, Ambient, Lounge
Generally, I'm happy(ish) with the sound, but I know it can be imporved.
What, in your opinion would be the weakest link in the above system? Perhpas I should sell it all and start rom scratch?
I'm a person, who always tries to get the best value for money. Considering that the above system costs circa £1k, would I hear 100/200/300% improvment if I spent £2/3/4k.
I always look on different components thinking, if I should upgrade the current system. I looked at Speakers: ProAcs D18, PMC 23, Spendor A6 | Amps: Naim, Cyrrus, Roksan, etc | DACs: M-DAC.
What do you think?
__________________
Jake Eliasz
davejberry
davejberry's picture
RE: What is the weakest link?
How could anyone define an improvement in percentage terms?
Any 'improvement' you envisage can surely only be defined as a difference in overall sound e.g.  sounding warmer or more clinical, because of more treble, more bass, a wider sounstage, clearer vocals etc.
IMO, you must first define what you think is 'wrong' with the presentation and then ask for opinion on what kit could help to rectify that.
__________________
LOUNGE: SONY KDL-46W4000; STR-DA2400ES & BDP-S350; SKY+; TOSH SD3010 DVD; PIO PD-F1009 MULTI CD; WII; KEF CRESTA 2 fronts,CRESTA 1 rears CRESTA CENTRE; BUDGET INTERCONNECTS & 79/42 STRAND OFC SPEAKER CABLES    BEDROOM: PANA TH42P-WD6;
eliotn
eliotn's picture
Thanks davejberry.
This is the main issue.
How can I define what is 'wrong', if I dont have a template what is 'perfect'?
I think I've never auditioned what is referred by audophiles - the 'hifi reference system'.
Shall I take a couple of tracks I know very well and audition systems worth £100k+?
__________________
Jake Eliasz
Covenanter
Covenanter's picture
I can't do percentages either but I would look for better speakers.
Chris
floyd droid
floyd droid's picture
Depends on your system matching abilities dunnit. Price dosnt have to come into it. I could easily lob a 4k system together that would sound absolutely dire. Sorry buddy but nobody can answer that % question for you. Its your ears and your room.
eliotn
eliotn's picture
Ok, lets drop the %.
Where or how can I audition a system, which is conisdered to be the hifi reference system?
I think this is the only way to move forward and improve my own system.
__________________
Jake Eliasz
Electro
Electro's picture
eliotn wrote:
Thanks davejberry.
If you need a reference go to Ronnie Scott's or similarly good venue when one of your favourite artists is performing and thoroughly enjoy yourself whilst making a concious note of how you feel.
Then listen to as many makes and types of HiFi equipment in different systems until you find a combination that gives you a similar feeling of musical pleasure to the live music that you heard at your venue of choice .  rockin out
This is what I have done an it has most definitely worked for me , but even if it does not work for you at least you have had a really good evening out . Wink excellent!
__________________
Electrocompaniet EMC1UP Cd player , EC 4.7 pre , AW120 DMB power amp , PMC PB1i speakers . Isotek Titan / Nova , Nordost SPM speaker cable , Kimber KCAG balanced interconnects .
Linn LP12 Lingo , Ittok lv3 , Lyra Lydian , EAR834P .
"Everything should be as simple as possible, but no simpler."     Albert Einstein .
BenLaw
BenLaw's picture
There is no perfect system. Work out your budget, draw up a shortlist (as you seem to have done) and go and demo, demo, demo. Once you've found the best system, draw up another shortlist from any more ideas you might have had and then see if you can improve on your choice. Demo at home if at all possible.
__________________
HiFi   /   A/V   /   Bedroom
eliotn
eliotn's picture
Electro very good advice, providing that I will remeber anything the following morning.
To be honest this is what I've been doing for the past 15 years. I've been chasing the feeling of being in front of the stage, while auditioning various kits. The only problem is that everybody has some budget to spend and it is hard to make a justified decision that the kit A (worth £5k) sounds sooo much better than kit B (woth £1k).
Unless, the kit A does give you that feeling of LIVE performance...
I think I need to audition more!!!
__________________
Jake Eliasz
eliotn
eliotn's picture
Thanks BenLaw
It sounds like the plan.
__________________
Jake Eliasz
floyd droid
Top post. I bang on about the importance of this like a stuck record. Home demo is paramount.
Nogsk
Nogsk's picture
I think the best place to start would be your source or sources. The best amp and speakers won't make a bad source sound better.
Most of my listening is by way of Flac files off a hard drive and the single component that made the most difference was the dac. Similarly if your medium of choice is vinyl or cd then look at quality decks and transports.
Demos are great if you can get them at home, but also be aware that the confusion of choice can lead to you going round in circles.
It takes time and experimentation to get the sound you want, at the budget you're happy with, that's part of the 'fun'. Good luck!
AlmaataKZ
AlmaataKZ's picture
Take your time to demo, to understand what you want, and then to demo again. Compare, compare and most importantly get to understand what is causing differences in sound. Choosing your next hifi is as interesting as enjoying it later, choose well to make sure it is enjoyable.
it took me 1.5 years to choose mine. Loved the process and very happy with the result.
speakers (and their interaction with room and amp) have the most effect on sound. Sources these days are far from being the weakest link. Be wise. Think it through.
Covenanter
Amen!
Chris
PS It seems to me that people on this forum spend far too little on speakers (and room treatments) and proportionately far too much on electronics.
lindsayt
lindsayt's picture
Scalford Hall, March every year. Please bear in mind the empty room acoustics and dining chair seating.
Or arrange your own bake-off. Or get together with a few hi-fi forum posters with interesting systems and go and visit them.
Personally I see scope for improvement of your source, amplification, speakers and room. The first 3 can be improved whilst keeping the spending below £1k.
Overdose
Overdose's picture
eliotn wrote:
Hi all,
My current system:
KEF Q300
Marantz PM6004
Room: 4x4m
What do you think?
The music? Tongue
__________________
Mac mini > AVI ADM9Ts
