What Hi-Fi Team - Help with budget system......please?
16 replies [Last post]
Paulq
Paulq's picture
Hi all
OK I am a bit baffled by all this as I want a decent separates system for a bedroom which is small (10 feet x 10 feet) and which is my escape 'den' in the house Smile.  I mainly listen to rock music and do like a 'weighty' sound but obviously not so much so that it sounds boomy in such a small room.
 I want to spend about 650 pounds on a system which will satisfy the kind of music I like but am stuck where to start to be honest and just confused by so many possible combinations.  So far, having done some research I have looked at the following components (accepting that not all possible combinations would be within budget..)
CD
Marantz CD6002
Marantz CD5001
Cambridge Audio Azur 340c
Cambridge Audio Azur 540c v2
Amplifiers
Marantz PM4001
Rotel RA05
Nad C352
Speakers
B&W 685
Cambridge Audio S30
Monitor Audio Bronze BR2
Can anyone make any really practical suggestions as to either combinations of the above or alternatives that I can get out there and listen to as, at the end of the day, my decision will be made on how they sound.
Would really appreciate some help so thanks in advance.
Paul
__________________
Main System:  Linn Majik DSM, Linn Majik 2100 Power Amp, Yamaha CDS300 CD Player,  Linn Majik 140 Speakers, Graham Slee Novo Headphone Amp. Synology DS212J NAS.
Headgear:  Denon AHD-7000, Beyerdynamic DT990, Beyerdynamic DT770 Pro, Beyerdynamic DTX101ie, SoundMagic E10, Sennheiser CX299.
Out and About: Apple iPad 3rd Gen. Apple iPhone 4s. Apple iPod Classic 160Gb. Fiio E5 portable Amplifier.
Andrew Everard
Andrew Everard's picture
Online
Re: What Hi-Fi Team - Help with budget system......please?
In a room that small I'd go for the CD6002, C352 and the S30s.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
Paulq
Paulq's picture
 Thanks Andrew I will have a look at that combo and listen to it. As an alternative which is well within budget how does this sound:-
Marantz CD5001
Cambridge Audio 340A SE
It's the speaker/amp choice which I'm struggling with as am pretty happy with the Marantz CD player which, for the price, is excellent. How does the above sound for rock music and any alternative combos you may suggest?
Thanks again.
Paul
__________________
marcymarc555
marcymarc555's picture
 Id try and strech your budget a little further in the amp department, the 340a doesnt impress me at all.
Marantz CD5001
Thanks again.
Paul
Paulq
Paulq's picture
 Thats the main concern I have as I want/need an amp that will drive the speakers properly but also so that I have the weight of sound that I would like.  I looked at the Rotel RA04/05 setup but that would put me at the absolute limit of my budget.
 Paul
__________________
Andrew Everard
Online
 Hence the NAD suggestion
__________________
matthewpiano
matthewpiano's picture
I've just got myself back into the seperates game by utilising my existing Bronze 2s and pairing them with a Marantz CD5001 and a secondhand Arcam Alpha 7 amp.  The Alpha is much better than Cambrdge Audio 340/540/640 (IMO from experience of trying the Cambridge amps at home) and drives the Bronze 2s with ease, getting the absolute best out of them.  The amp cost me £75 on a well known auction site and this makes for a very well matched and musical system which works with a whole range of music.  I think you'd have to spend a lot of money to improve on the Alpha as an all-rounder, and the CD5001 is a much better source than its low price suggests.  Hope this helps.
__________________
Rega RP3/Elys 2, Roksan K2 CDS, Squeezebox Touch, Denon PMA720AE, Q Acoustics 2020i, Sennhesier HD595, Beyer-Dynamic DT770PRO, Chord Crimson/Chord Rumour 2
matthewpiano
Oh, and that will leave some budget left for some decent speaker stands which will bring massive dividends with the MAs.  I use Atacamas and they really provide solid support for these superb speakers.
__________________
Paulq
Paulq's picture
 It helps a lot thanks very much.
I guess what I was really after  from my OP was a view from Andrew/Clare as to, in a room the size i have, which kit they would use as the ideal budget system which may not include the list I quickly put together as options as my knowledge is very limited.  I am new to this so working blind a little bit but, following comments on here I am tempted to go for the following set up:
Marantz CD5001
NAD C320BEE/C352 Amplifier (would the C320 do the job instead f the C352?)
B&W 685 Speakers
That (using the C320BEE amp) would just squeeze into my budget.
Would appreciate any views/alternative suggestions but thanks for all help so far - this is a minefield as you just don't know what is quality and what not.
Paul
__________________
robg1976
robg1976's picture
hi mate im sure any of the above metioned set ups will be a great budget system try to audition them if you can you might be suprised........
And Andrew its nice to see you reccomend the NAD c352 and not the the usual Cambridge audio this forum is filled with........The c352 sound great and will drive any speakers with great sonics and cotroll
__________________
Paulq
Paulq's picture
Cheers Rob
Any comments on whether the NAD C320BEE would do the job for me - would keep within my budget.
Pretty Please? ConfusedConfused
__________________
d_a_n1979
d_a_n1979's picture
In my opinion i'd rather go for a 2nd hand Arcam 7, 8 or 9 amp off Ebay and leave the Nad. I have had the Nad before and thought it was very good until i went over to an Arcam Alpha 8 amp and that left the Nad high and dry.
Arcam Alpha amps seems to have so much more crispness and punch/clarity in the bass, especially if matched with good stand-mount speakers (for a small room). The Arcam would suit the B&W speakers so well and as someone said before, get some good decent Atacama speakers stands (id go for the Atacama SE20 or SE24 stands) and you've got a cracking systems there.
There are some very good bargins to be got on Ebay currently, my 2nd system has all been sourced from Ebay and if you do your research good enough and make sure that you are buying from a trusted seller, you cant go wrong.
As for a CD player, the Marantz that Andrew mentioned above would finish this system off nicely and would suit your taste of music down to a tee! I listen to Rock and Metal quite a lot, as well as all the other music i'm into, and i'm still to find a Amp and Speaker package to better Arcam and B&W.
Let us know how you get on.
bloney
bloney's picture
Hope I'm not out of order here - Mods delete this if I am!
I happen to have a Arcam Alpha 7 I'm looking to sell. If you might be interested, lettuce know.
The Arcam does sound very nice - smooth and rich and easy. Bought it 2nd hand to see how it sounded, but I think my original CA 740A has more punch and detail. If you're interested and don't live too far away, you'd be welcome to come and listen and see what you think with no obligation.
Bloney
Fraziel
Fraziel's picture
The b & w's are far too big for a room that size, as i suspect are the BR2's.Have you heard the 685's? they have a really big sound suitable for a fairly big sized room. they would not sound good in a small room like that i think. They are also in a different league to the BR2's, in my opinion.
have you considered the B&w 686's?' They are more than big enough for a room that size and sound stunning.
anyway, from your list it would be nad amp, Marantz cd but not sure about any of the speakers.
Paulq
Paulq's picture
That's really constructive advice and the honest answer is that no I hadn't but I have taken a look at them and certainly will give them a listen.  I am pretty much settled on the Marantz CD and B&W's now but still pondering the amp - would the NAD C352 perhaps be a bit too much also and the C320BEE be a better option? Are there any Marantz amps in that ball park worth considering?
Thanks again.
Paul
__________________
Fraziel
Fraziel's picture
i would definitely try out 686's.They sound very like the 685's but just not as heavyweight.They would be ideal for your room size.Buying them would save you over £100 which you could use to get a nad 352 which would drive them with ease i reckon.
