21 posts / 0 new
Last post
krish123's picture
Last seen: 5 months 3 weeks ago
Warm, sweet and smooth sounding speaker cable and interconnects.
Im looking to upgrade my interconnects to achieve a warmer sound with sweeter mid range etc. Can any1 reccomend me both speaker cable and interconnects for this job?
i will be buying second hand and have a budget of £50 for i,c's and upt to £100 for speaker cable.
Thanks.
CnoEvil's picture
Last seen: 3 days 13 hours ago
RE: Warm, sweet and smooth sounding i/c and s/c
Linn Black I/C + Linn K20 S/C (both on ebay)
Van Den Hul
Van Damme
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
matthewpiano's picture
Last seen: 3 weeks 3 days ago
What equipment are you using, and what is the listening space like?
Rega RP3/Elys2/TT PSU- Denon DCD720ae - Pioneer A400  -  Wharfedale Diamond 220 - Atlas Equator 2.0 - Beyer DT-770PRO - Mission stands
chebby's picture
Last seen: 16 hours 29 min ago
Chord Chrysalis interconnects. (You will only find second-hand ones.)
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
plastic penguin's picture
Last seen: 1 day 23 hours ago
Snap! perhaps, also, with cheapish copper speaker cables from Richer Sounds.
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
krish123's picture
RE: Warm and smooth sounding speaker cable and interconnects.
thanks for the replies so far guys. i am definately inclined towards van den hul, just which particualr model? i believe the integraton is a good cable?
my current equipment is pass labs x5 power amp (soon to be changed with a 2 channel one) musical fidelity a5 preamp and sugden cd21 series 2 cdp. Speakers are monitor audio rs6.
Im happy with the sound, just want to make it more warm if possible. im hoping to partner my a5 power amp with a matching musical fidelity power amp to create better synergy between components.
the room atm has just been converted so has wooden floor, no blinds as yet. room is pretty bare atm, with just a snooker table in the middle.
i have placed 2 pieces of carpet under my speakers which improved the sound i would say.
keep the reccomendations coming guys.
CnoEvil's picture
Any slight brightness is likely to be a mixture of your speakers and the room acoustics.
What are your cables at the moment?
krish123's picture
RE: Warm, and smooth sounding speaker cable and interconnects.
i agree that the speakers are attributable to the bright sound, however i have found ways to tame this. my speaker cable was originally qed xt350(containing silver) which i changed to qed original biwire, with improved results. however i dont have suffiecient length of this cable really, and feel perhaps i cud gain even better results with better speaker cable.
interconnects i used jps labs ultra conducter and van den hul the bay. i swaped around my jps interconnect for a cheaper ixos one and again the sound was less bright. so i just want to match everything up in terms of sonic signature of interconnects and speakers cables.
the record spot's picture
Last seen: 1 year 9 months ago
Some multistrand speaker cable will be good - 400 or 500 strand, while for the money you're looking to spend, any branded copper cable will do.  I use Computergear ones which cost me £8 and are virtually indistinguishable from the Atlas Navigators (£220+) which they replaced.  You pays your money...
Kevin Stephens's picture
Last seen: 2 years 2 months ago
With a system as good as yours I think you would be missing out on the potential of your components at only £50 for interconnects. I was amazed at the difference Chord Chorus 2 made to the warmth and clarity of my MF A3.5 system. Any good dealer should be able to lend you samples of ICs for home demo if you leave a deposit
krish123's picture
RE: Warm,and smooth sounding speaker cable and interconnects.
hi kevin, remember this is the second hand price im willing to pay so can get some gd deals, how would you describe the chord chorus interconnect's sound?
Overdose's picture
Last seen: 2 years 2 days ago
If you are yet to fully furnish and decorate your room, I'd be inclined to wait until it is all finished. You will be surprised at the sound difference. At that point you will be in a better position to decide what it is your system appears to need.
shooter's picture
Last seen: 2 years 8 months ago
+1
BenLaw's picture
shooter69 wrote:
+1
+ 2. This will have a much bigger difference on the sound than cables possibly could.
If the room were finished, I was going to suggest spending your money on acoustic panels, which again have much more chance of taming brightness than cables.
I am the danger.
krish123's picture
i agreee about the comments on the room guys, but my cables need changing anyway, so just looking for cables that suit my taste really. iv seen van den hul magnum speaker cable which looks good for what im looking for.
Any other reccomendations?
CJSF's picture
Last seen: 6 days 7 hours ago
You sure you are on the right track??? 'Looking good'?, perhaps I'm taking your statement to literally, but some of these cables 'looks nice', cost a lot and deliver very little more, if any, for the extra premium? The only way is to audition if you possibly can, especially in a room thats lively?
I have done some listening recently with cable that ranged from £5pm, £16.50pm to £45pm, see; 'you pays your money and takes your choice'. The 16.50 cable was a disaster, the £45 and £5 cables were as near as could be, a draw (according to taste;) ) . . . its a no brainer IMHO.  For £5pm you dont get eye candy, however you do get a prestigious name: like Linn:cheers:
CJSF
Pages
Log in to post comments
