Wall mounted speakers/supports for CR603
1 reply [Last post]
jaffers1969
jaffers1969's picture
I am planning on buying a Marantz CR603 for my kitcken/dining area since I spend an awful lot of time in there Smile
Due to lack of space, the speakers will need to be wall mounted at one end of the room.
Can anyone recommend a suitable set of speakers for wall-mounting and supports for them. Ideally I'd like the speakers to be as small as possible without compromising sound.
My budget is £250 for speakers and £30 for mounts.
Zia
beneboy74
beneboy74's picture
RE: Wall mounted speakers/supports for CR603
Try Dali Lektor 1 or 2 speakers. There is a recess in the back of speakers so they can be wall mounted by hanging them off screws.
