10 posts / 0 new
Last post
Ambrose's picture
Last seen: 1 year 11 months ago
Wall mounted speakers still good hi fi?
What do people think?
Apart from room space gains and being away from little fingers..... is it worth it?
Please share experience / examples.
Ambrose
TheHomeCinemaCentre's picture
Last seen: 3 years 1 month ago
Re: Wall mounted speakers still good hi fi?
They can be - PMC Wafer 2 is a good example of an on wall that performs. I have a set of Meridian P320's at home at the moment and they sing. To really work they need a sub though and that can cause an issue.
chunky70's picture
Last seen: 1 month 3 weeks ago
If they are designed to work close to the wall and have front firing bass ports i don't see how they woudn't sound good.
Anonymous's picture
pmc db1i's are designed to go on the wall without compromising hi-fi
MUSICRAFT's picture
Last seen: 1 day 6 hours ago
Ambrose:
Ambrose
Hi Ambrose
Yes, wall mounting speakers can be still be worthwhile provided speakers are chosen and implemented with care. ATC offer SCM-7S and SCM-11S on wall versions of their excellent SCM7 and SCM11 monitors Smile
All the best
Rick @ Musicraft
Musicraft (Derby) - Specialist Hi-Fi/AV Dealer
My system - Naim Core > Hegel HD30 > Hegel P30 > JL Audio CR-1 > ATC SCM100ASL Professional Monitors > 2 x JL Audio E-112
6th.replicant's picture
Last seen: 3 years 5 months ago
Seem to recall reading an article about a hi-fi install for Rachel Weisz's - by all accounts, 'our Rach' is a bit of an audiophile - music room/study, which has an odd shape, so she chose wall-mounted Spendor SR5s.
Anonymous's picture
I've heard several. The only decent ones were the Sonus Faber Elipsa.
Ambrose's picture
So there are good speakers "Real Hi Fi" quality in wall mounted speakers, but at a cost by the looks of it Sad
Anyone suggest something cheaper that would work with AVR 280 Amp and Marantz DVD player? I have MT20 Sub also.
Speakers budget £300-£500, including second hand. A couple of ideas for these Dali Lektor 2 / AVI neutron 5 / PMC DB1+ (second hand) / Rega RS1???
Possible options to upgrade source to CD later on / stereo amp etc. Room size 15ft square.
Ambrose
chris hollands's picture
Heard the new Totem on walls at the Bristol show, thought they were awesome !!
However they were £3200.
Al ears's picture
Online
Last seen: 20 hours 8 min ago
Ambrose,
Out of the speakers listed I would suggest the Dali's might be best choice and easy to audition, if you are buying the PMC's second hand and you decide you do not like them you should have no difficulty selling them on, these would be my second choice.
You mention 'out of reach of little fingers' but be aware none of these speakers will sound their best if mounted way up the wall.
You would, ideally, still need to mount them so the tweeters are approximately level with your ears when in your normal listening position.
Motto: Never pay full price for anything, there is always room to haggle!
Tom Evans Audio Design amplification / Acoustic Zen Adagio speakers / Dr. Feickert Analogue Woodpecker-SME310 / Oppo 105eu
Log in to post comments
