4 posts / 0 new
Last post
goalhanger's picture
Last seen: 2 days 11 hours ago
Vintage Celestion speakers
Hoping someone on here can help! Just bought some Celestion Ditton 332s  for £20 but one of the midranges isnt working , swopped over and it is the speaker thats gone. I like the sound as my Dad has 33s so i'd like to fix if I can.
Unfortunately its not the same as the 33s midrange and I cant find any mention on the web .The number on the speaker is EN20. Does anyone know if there are replacements available anywhere ?
Maybe i should have waited for some fully working 33s to pop up in my area ;-(
Thanks,
Phil
Sony KDL-50 TV, Marantz NR1604N, Boston Acoustics XS 5.1, Sony BDP S360, TiVo
Marantz PM6300, Technics SL-B2+Ortophon VMS20E, Phillips CD, Rega RS5 + Rega cable, Grado SR80i h/phones.
Anonymous's picture
RE: Hi-Fi
Did a quick search on the interweb to no avail for you. Will a same size driver not work?
Bumping for the OP. Cool
RE: Hi-Fi
yep i dont mind replacing both but i would like similar sound so need equivalent -  big magnet etc etc ...
dont know enough to pick a replacement. have DK loudspeakers no. which i will try tomorrow, but as Dave the speaker guru may well be in his 80's I will wait to see !
Phil
RE: Hi-Fi
I have found that I can get replacements from SEAS for both tweater and mid-range . But I have contacted DK loudspeakers in Hornchurch and am dropping them off tomorrow so he can take a look. They re-coned my Dads Celestion Ditton 33s a while back and tweaked the crossover and they are superb .
Phil
Log in to post comments
