Valve amp
61 replies [Last post]
Macspur
Macspur's picture
Well, I've now heard two of the best Class A amps in the IA-4 and AMS 35i
and neither quite give me what I'm looking for.
The dealer has now suggested I demo a Mastersound compact 845... anyone with experience with this amp, or anyone used any valve amp with Harbeth... a good match or not?
Mac
__________________
Accuphase E350 amp, Electrocompaniet EMC1UP CDP, Siltech 25th Classic anniversary 330I  XLR Harbeth Super HL5 on Sound Anchor Quod ELS63 stands, Chord Odessey2 speaker cable.  Grado SR60 headphones.
CnoEvil
CnoEvil's picture
RE: Valve amp
I can't help you with the Mastersound, but I strongly suspect that you are a good candidate for Valves....you could also check out Icon Audio, Unison Research and of course Jadis.
Can you describe what you are looking for, and what the above two amps are missing?
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
Macspur
Macspur's picture
RE: Valve amp
I mean it when I say the Sugden and MF aren't far away from the SQ I'm looking for... they just lack that bit of reality, depth and space between instruments.
Perhaps I'm looking for something that's unatainable without spending a fortune!
Just been reading up on the Compact 845... it does seem like a lot of faffing about when setting it up and having to bias it every 6 months.  I suppose it would be the same with any valve amp.
I will probably give it whirl in a couple of weeks, just to satisfy my curiosity.
BTW, got some Audio Quest cables coming tomorrow... you never know they might just do the trick.
Mac
__________________
CnoEvil
CnoEvil's picture
RE: Valve amp
I'm nutty enough to believe that if you're "not far away", the right cable (mains/speaker/interconnect) along with Black Ravioli does just that.....if you haven't already done so, also borrow a good Audioquest mains cable (I've heard them make a good difference).
__________________
Macspur
Macspur's picture
RE: Valve amp
I believe you Cno! excuse me if it's a silly question... mains cable for the amp?
Mac
__________________
CnoEvil
CnoEvil's picture
RE: Valve amp
Not a silly question at all.
I found that a decent cable on the amp was worthwhile, and also a cheaper one on the CDP. I have got the best gains from the amp, and lesser gains on the source (and no gain on my Linn DS).
This is a very much a trial and error thing, as it has different effects, on different kit, in different houses. All I know is that it's worth experimenting with, as the posible rewards can be surprising, and bigger than an i/c change.
If it doesn't work, then there's no harm done. Look to Audioquest NRG4 or 10 for the amp, and maybe an NRG-1 for the CDP. I also rate Cardas, Furutech, Nordost and Clearer Audio.
Black Ravioli under my Linn DS also helped in the areas that you are talking about.
Cno
__________________
paradiziac
paradiziac's picture
RE: Valve amp
Harbeths and valves I imagine would be great if you like falling asleep to your music, though there are people that like the combo.
Based on your comments of what's missing and the ability of the amps you've tried, I doubt the problem is the amp.
I'd also try to experiment with or borrow cabling/equipment supports.
Are you using a mains block or direct to wall sockets?
Rethep
Rethep's picture
RE: Valve amp
I think you must decide for yourself if you like "valve-sound" better. Then you could also try (cheaper) valve-amps like Cayin or PrimaLuna which are based on EL34 or KT88 valves.
__________________
Airport Express (still analog)/Meridian 206B (cd-player), Artephonos Energa (power-tube-amp), Epos ES-11 (speakers). Panasonic TX-P42G30 (tv).
batonwielder
batonwielder's picture
RE: Valve amp
So what it is that you are exactly looking for? I would start thinking about changing the speakers if Sugden or MF didn't do it for you.
Try Naim with Harbeth if you are reluctant to do so, starting with the separates.
Macspur
Macspur's picture
RE: Valve amp
Thanks for the suggestion, but been there done that.
Won't be ditching the Harbeths any time soon, love them.
I may be chasing the unattainable, but I'm looking for that bit more lifelike sound and if valves don't give me that, I could easily live with the Sugden Harbeth combo for a while longer.
Mac
__________________
acalex
acalex's picture
RE: Valve amp
Mac
Mac, as you know I have a valve amp...not sure what you mean by lifelike sound. The comb I heard AMS35i + Avalon Idea was the most lifelike sound I heard...it just sounded right. Guitar sounded exactly how it should....and separation of instruments was neat
On the other hand, I still preferred the tube sound because a bit more emotional, coloured...but I would say it is less "lifelike" if I understood correctly what you mean by the term. It is an amazing musical and emotional experience. You won't get over the heat problem though as my Jadis D50 Signature heats quite a lot...
The only tube monoblocks I heard were stunning...and had anything I could really complain about...but at what price? Over 25k euro...
tino
tino's picture
RE: Valve amp
Have you listened to (or can you arrange to listen to) any hybrid integrated amps ... e.g. Unison Research Primo/Secondo or Pathos Logos/Ethos?
__________________
Squeezebox Touch | Wadia 151 | Aliante Moda PF
shafesk
shafesk's picture
RE: Valve amp
Mac
I don't see why a tube amp won't be a good match for your Harbeths. Do try to get something with some grunt as tube amps are relatively low powered as you probably know. I would recommend looking at the Cayin a-55T, but if you are looking to fill a large room these are not the ticket at 45 watts/channel. Although Harbeth suggests that you can get away with 25 watts per channel for this particular speaker, only an audition will tell.
__________________
Hi-fi:
Denon DNP-720AE network streamer, Mordaunt Short Mezzo 6, Cayin A-55 T, Technics-SLQ210, Denon DP-29F turntable, 540p, Dac-magic, Marantz 5004CD and 6025 Turntable, Mac ,Pure AV interconnects, QED Revelation speaker cables, QED Performance interconnects.
Head-fi:
Akg K702, Grado SR60i, UE Triple-fi, Musical Fidelity X-cans, HRT Music Streamer 2+
shooter
shooter's picture
RE: Valve amp
Thaiman used to have a Mastersound, not sure which one. Maybe start a thread in it and he may pop in Smile
oldric_naubhoff
oldric_naubhoff's picture
RE: Valve amp
I say you should give the Mastersound a try. what do you have to loose? Italians know how to make hi-fi gear sound involving. who knows, maybe you'll enjoy what you'll hear?
on technical side of things; no feedback amp is always striking a the right chord in me. it means the design and components are good enough so there is no need to apply feedback to lower THD. some people think that feedback kills music too, but that you'll have to find for yourself. there's no way you can do a bench test to measure that factor. 845 tubes are also very powerful so you get quite a lot of grunt for a SET amp (in this case some 30W, whereas with a 300B tube you can count on some 12W tops with loads of THD at such a level).
I personally had Mastersound amps on my radar as well, mainly due to no-feadback design. but I must say that for an Italian design they don't shine in aesthetics department IMO. but tastes differ... and there's Pathos which shares similar design philosophy but looks gorgeous, IMO, to boot. if you get a chance try Inpol2.
there's one more thing about no-feedback amps which makes them less suitable to wide range of speakers. they usually have comparatively high output impedance, hence low damping factor. don't get too much worried if you're amp doesn't have 10000000000000 damping factor. a factor of about 50 is as  good as any (I can post a lint to article if someone is interested). but there's another concern. high output impedance makes the amp vulnerable to varying impedance of the speaker and through that frequency response of the  amp may start fluctuate with frequency. to remedy that you need a speaker with high impedance plot (8 Ohm typical minimum, not falling below 6 Ohm) and if the impedance is flat (so called "purely resistive") it's even better because if speaker's impedance doesn't fluctuate amp's frequency response won't fluctuate either (planar magnetic speakers; hint, hint Smile). anyway, I think your Harbeths shouldn't cause too much distress to the Mastersound.
__________________
Giro, InTheGroove, Digit, ClassicOne, MG12
BenLaw
BenLaw's picture
RE: Valve amp
Mac
With what you've said here Mac, I really feel you ought to listen to some active ATC 50s or 100s, even just to rule them out. They are class A up to 2/3 of their output (ie class A for any realistic volume levels), but don't run too hot. They are the most 'lifelike' speakers I have ever heard, and shouldn't overwhelm your room with bass.
Cheers,
Ben
__________________
HiFi   /   A/V   /   Bedroom
