9 posts / 0 new
Last post
jcarruthers's picture
Last seen: 3 years 3 weeks ago
USB to S/PDIF
Hi all,
Are there any decent cheap USB to S/PDIF convertors that can cope with 24 bit 96 kHz.
My MacBook Air doesn't have an optical output and my Pro has been locked down by work so I can't use Audirvana etc
James
BronC's picture
Last seen: 2 years 6 months ago
RE: USB to S/PDIF
Musical Fidelity do a vlink2 that does exactly what you want.  You should be able to pick up a 2nd hand one for about £60.  They also do on that handles 24 192 - but that is a lot more expensive
sogophonio11's picture
RE: USB to S/PDIF
What do you determine as cheap?:quest: :?
RE: USB to S/PDIF
Dirol Yes BronC was thinking the same as me!
ngibbs's picture
Last seen: 1 month 12 hours ago
RE: USB to S/PDIF
jcarruthers wrote:
Hi all,
James
My M2Tech Hiface 2 is good. About 100 quid I think
BlueSound Node Streamer, Metrum Acoustics Octave DAC, Pure Sound L10 Pre, Nord One Up Stereo Power amp, Vienna Acoustics Hadyn (study)/ATC SCM11 (kitchen) via Beresford Speaker Switch
Ajani's picture
Last seen: 4 months 3 weeks ago
RE: USB to S/PDIF
I use an M-Audio USB Transit. Just 100 USD when it was new. It's discontinued but you might be able to find used ones for really cheap prices.
M-Audio USB Transit -->Benchmark DAC1-->Beyerdynamic DT880 600 ohm / AKG K701
ngibbs's picture
RE: USB to S/PDIF
ngibbs wrote:
jcarruthers wrote:
Hi all,
James
http://www.whathifi.com/forum/computer-based-media/how-tog-get-the-best-sound-from-a-pc
RE: USB to S/PDIF
The Musical Fidelity sounds good - in fact my old V-DAC is on eBay finishing today.
Amazon have them for £100 so it looks like it'll pay for it.
csq2's picture
RE: USB to S/PDIF
Musical Fidelity V-Link II for the price. Though, Stello U3 is the best!
Log in to post comments
