Tube rolling
Hi All,
Im looking to change the standard chinese tubes in my disc player and have narrowed it down to 3 makes;
RCA 5670
WE 396A
Los Gatos 5670
Is there anyone who has any experiance with these tubes? What are the differances in sound? Has anyone got other suggestions?
Thanks in advance
MrB
Stock tubes from what? the same CD player? if so what were the gains you found?
No, in my case it was in a pre-amp, just one actually for the line stage. I think the stock tube was from a company called JJ, the dealer lend me a Mullard to try. It was better but only marginally so. They can have slightly different sounds though for sure. Mullard are very well regarded.
I've tried Tung Sol (NOS) and WE tubes. Tend to prefer the latter (higher frequencies, esp piano, seemed clearer), although different speakers may give different results - I already know the amp well enough!
I've got 9622 tubes in my amp and CDP. originally there were JJ tubes in amp and Electro Harmonix in CDP. changed them for some cheap as dirt NOS Jan Phillips tubes. I find them more to my liking. JJ and EH were too mellow. Jan have more snap and thump.
Mr Beachams, slightly off topic I would be interested in any info on the hand build Morel speakers.
Regards.
In days of yore, when I used to play with valve amps, the best valves were made by Telefunken. Mullard and GE valves were also highly thought of.
Chris
Tube rolling.......They are called valves.
Well thanks everyone for all your responces, seems to me its down to try it and see which i think is the way to go, think i will hunt down some WE's first...just hope i can get them in the UK.
Hi Will, I know you know the amp well...... I bought it from you lol and am very happy with it
...thankyou.
Regards.
I will start a new thread on these and will post some pics once i sus out how to do it (any clues are welcome lol)
- Login to post comments
I swapped my stock tubes with Mullard.
