Thoughts and advice for new system
Hi all,
It's been a while since I've posted on here and after donwsizing my system and moving house I am ready to start building a system from scratch.
My listening space is around 4.5m x 6m and I will be sat between 2m and 4.5m away depending on whether I am sat on the sofa or at the table behind the sofa. Speakers can be either right up against the wall or 30cm away.
I tend to listen at fairly low to medium levels as I now live in a 2nd floor apartment although we don't have anyone above or any of the sides, just below.
I listen to all genres of music. Indie rock, ambient, electronic, chill, trance, acoustic. Pretty much everything but those are the main ones.
I will be using the Sonos connect to stream all my music so will be needing speakers, amp and a DAC. I really want to be getting a full, thick sound from low/med volumes, lots of detail, a good weight to the bass without being boomy and a good separation and sense of spaciousness. One thing I don't like is overly forward treble or anything that becomes fatiguing.
On Friday I demo'd some MA RX1s in gloss white with the Arcam A19 and Audiolab 8200CD at Frank Harvey in Coventry. I wasn't too prepared for the demo so I didn't have any of my own music with me but David leant me one of his CDs which was perfect for my tastes. (AES Dana) Very laid back electronic ambience.
I found the level of detail amazing. Everything seemed to be there and the speakers seemed to just disappear and I found myself not able to or wanting to move from my seat. It was almost as though I had taken some relaxants and was having a massage at the same time.
I then tried some other tracks, Ocean Colour Scene and Foo Fighters. Although they sounded very good, I was able to tell they were coming from a small speaker. Some of the more complex guitar and drum sections when it got going seemed to sort of get a bit mixed up.
Although, this was still one of the best sounds and combinations I've heard from hifi I am still wondering if there is a better combination.
I am going back in on Saturday to try the MA RX1, RX6, audiolab 8200p, Roksan Kandy K2 integrated and Arcam A19 in different combinations.
I think that the RX6 might provide that little bit extra that I was looking for in terms of scale and depth but they come in at over twice the price I can get the RX1 for. The RX1s might actually give me the extra warmth and depth when I get them into my small furnished living room.
Does anyone have any advice on other speakers or amp combos I could look at? I do want a good quality integrated or pre/power that I won't have to upgrade if I ever want to replace my speakers for something slightly better. I was thinking of the Audiolab 8200CDQ/P combo but starting with the 8200P with the Sonos as the pre until I can afford the CDQ. Or if I prefer the sound of the A19 or K2 saving for one of those instead.
I will be able to buy the amp once I've sold my beloved Epos ELS3 7.1 setup which is just sitting in their boxes at the moment.
Thanks hoopsontoast, I was thinking of the Rs3 and Rs5 as they get great reviews. I also saw the Neat Motive 2's and 3's on their site and thougt it might be worth giving them a listen too.
I have actually owned the SCM11 and the 19s along with a musical Fidelity A5. Great speakers but the room I had them in was way too small for them to sound good and at the time needed the cash so I sold the lot.
I'm trying to be a little more sensible with what I spend now and ideally I'd be spending £500 speakers, £700 amp and £300-£500 DAC. I know I will probably have to spend just over this for the speakers and amp. But if I try a combination for less than this that I really love I'll be very happy
Was also thinking of the R100 or R300.
But I loved the sound of the RX1 that much that I know I would be happy to buy them. I just don't want to only try the one pair though, in case I do prefer something else. I was just left wanting a little more bass depth.
Yep, always worth hearing as much as you can
Not properly heard the R-Series or LS50 to be honest, so cant really comment on them.
Perfect fit ?
http://www.avihifi.co.uk/adm9.html
http://hddaudio.net/
Hi Richard,
I have looked into and been tempted to try the ADM9s due to the quality, ease and simplicity and always thought that is the way I'd go.
But......when it comes down to it I really like the process of putting together a system that I can tune perfectly by mixing and matching and eventually upgrading or swapping out components as and when I feel like it.
I also, want to support my local hifi store (Frank Harvey) as they have always given me great service and given up time for demos and advice.
Maybe see if you can get a demo of the Rega RS3 or RS5. The ATC SCM11 may be worth a demo while you are there too, I prefer the SCM7 but you may prefer the slightly deeper bass that the 11 gives over the 7.
The SCM7 went really well with the 8200A.
They have some B-Grade Neat Motive 2's in budget, not my thing but some people rate them.
I am sure someone will be along to recommend the LS50.
Sony DVP-S9000ES | Doge 8 | Decware Zen | Veravox DIY Speakers / Eclipse TD-508 / Keesonic Kolt
